Rebuilt transmission: differential spins freely?
Old Jun 4, 2007 | 08:22 AM
redbarchetta's Avatar
Default Rebuilt transmission: differential spins freely?
I have a d-series rt4wd transmission which I have finished going through to replace bearings in the transfer gear. Transmission is reassembled and back on the motor, but not in the car yet. It will shift through the gears just fine and the transfer gear moves freely when 4wd is disengaged. Before installing the transmission on the block, with 4wd engaged, the transfer gear would spin and the input shaft would spin as well, so everything seems right there.
Problem is, after mounting the transmission, when I installed the intermediate shaft I noticed that it will spin freely regardless of if the transmission is in gear or not. I don't believe that is right. With the clutch engaged and trans in gear, the axles should not spin freely should they?
If it should not, any transmission gurus have any insight into what I may have done wrong and what to look for. The differential was working fine before the disassembly, only the 4wd transfer gear bearings were shot.
** EDIT: well after more searching... looks like this is correct.. need to get the other axle in and make sure it spins the opposite direction
Modified by redbarchetta at 10:19 AM 6/4/2007
Old Jun 4, 2007 | 09:28 AM
02 accord's Avatar
Default Re: Rebuilt transmission: differential spins freely? (redbarchetta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redbarchetta &raquo;</TD></TR><TR><TD CLASS="quote">need to get the other axle in and make sure it spins the opposite direction </TD></TR></TABLE>
Exactly.
Bob Dole!
Transmission & Drivetrain
Apr 20, 2025 07:42 AM
corpsebesideme
Jan 8, 2018 01:40 PM
teamasr1
Mar 21, 2010 09:31 PM
092eg6
Dec 2, 2009 01:33 PM
not so civic
Jun 18, 2003 09:07 PM
