EP3 Wheel size and offset?
lug pattern: 4x100
Not sure about offset.
16"s will fit fine, even with normal tires.
Ive also seen 17"s with no problems... 18"s depend on tire width.
Most tire shops online let you plug in your car make and model, just try that and copy the info it gives you for your own purposes.
lug pattern: 4x100
Bolt Pattern: 4x100
Offset Range: 35 to 45
Wheel Size Range: 14x5.0 to 19x7.5
OEM Tire Size: 185/65-15 (185x621 mm)
That's factory, but will these fit without rubbing in the wheel well?
Offset: 42
PCD: 4x100
With this size tire on them?
Size (mm): 215x625
I'm a noob at wheels.
Offset: 42
PCD: 4x100
Size (mm): 215x625
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlucardX666X »</TD></TR><TR><TD CLASS="quote">Bolt Pattern: 4x100
Offset: 42
PCD: 4x100
Size (mm): 215x625
Its cool.
Lets look at the numbers:
Wheel:
17" rim, 7" wide
Tire:
8.4646" Wide (215mm), 3.80907" Height (8.4646width*45%)
Offset is positive, so the tire will set to the left of the wheel center (away from the car)
So the tire is 1.4646" wider than the Wheel, which may cause problems. As a general rule, the tire's width shouldnt exceed the width of the Wheel by more than 1"
The Wheels are fine, they will fit on the car. The Tires may cause some rubbing problems on the inside wheel well though because of their width.
http://www.procarcare.com/icar...s.asp
Offset: 42
PCD: 4x100
Size (mm): 215x625
Its cool.
Wheel:
17" rim, 7" wide
Tire:
What tire size would you recommend for the size wheel I have chosen?
You seem to know alot about wheel and tire fitment and I appreciate your help alot.
it should fit... i use to have 17x7 215/45/17 lowered 2inches 45mm offset no rubbing at all, believe me i tried to make them rub too. but mine is an 04 model, but im sure it will not rub
