resistor box install EK
ok.. all the how to's are for eg's.. i dont have that same plug.. i was just going to mount the box in the same spot and extend the wires to the injectors and wire them in.. the ny thing i dont know is if the box wires replace the old ones goin to the ecu, or do you just splice them inline...
so i leve all the factory wires there, but simply splice the resistor box wires into the power wires?? or unhook the power wires and replace them with the resistor box wires?? andthen the red wire goes to switched 12v right??
I found the 4 yellow/black wires that had power, on the dead end plug under the I/M. Splices those wires with each of the black ones from the resistor box. Found the one black wire on the dead end box that got power and spliced the red from the resistor box to that.
