Ef D16Z2 Homocinetic joint
My name is Leo, 26 years old, from Croatia, car is EF ED7 D16Z2 (same sh*t as D16A6 ?) 110 hp SOHC.
And now, the first question...
Are the homocinetic joints on the 4th gen, on models : 1.4 dual carb, 1.5 dpfi and 1.6 sohc (mine), all the same or not? I am reffering to the outer homocinetic joint, between the axle and the wheel...anybody?
Yes, I do mean the ball joint, just didn't express my self right....thanks 4 the info... if you know what do I mean, my ball joints (outer ones) are making "the clicking sound" when I turn the steering wheel all the way, like "tok tok tok"....it's getting on my nerves.....
Thanks 4 the info..... my outer ball joints (couldn't find the right way to express myself
are making aggitating noise when I turn the steering whell all the way....like "tok tok tok"....frend has a 1.4 dual carb 91 civic that I can salvage for parts....I hope they'll match!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">I think you're probably actually hearing the CV joints in the axles.. </TD></TR></TABLE>
i agree....get under the car and look at the axles (driveshafts) going to each of the front wheels. each one has 2 rubber boots protecting the joints. if those rubber boots are torn, then sometimes they will 'click' when you turn the steering wheel.
ball joints are the little swiveling parts that are at the end of your tie rods, & upper & lower control arms. if those go bad, you will feel free play in your steering wheel, but they don't usually click.
I did mean the CV joints, but just didn't find the right words....they are between the axles and the wheel (sort of...), am I right? When I corner (on the small radius) I hear clicking noises, I had that problem before on my Opel
......just wondering if someone knows, could I use Cv joints from 1.4 dual carb....don't know are they the same, will they match?....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 »</TD></TR><TR><TD CLASS="quote">I would just take both axles out, set them next to each other and look at them. It should be obvious if they are the same.
count the splines.. that would probably be the only difference to look out for
</TD></TR></TABLE>count the splines.. that would probably be the only difference to look out for
Will purchase new set of CV joints from a local dealer...outer ones... I have a Civic manual, and a Haynes manual, but if anyone has a link to DIY CV joint replacing I would be more than greatfull....thanx
gsr_b20b
Nov 17, 2009 02:17 PM
simons civic
Jun 16, 2009 10:58 PM
Sensei
Jul 20, 2005 08:50 AM
