what kind of whp can i expect from all motor sohc?
Old Jun 3, 2007 | 07:06 PM
94civiclover's Avatar
Default what kind of whp can i expect from all motor sohc?
looking to build all motor single cam have hi comp piston and also skunk 2 intake manifold and 66mm tb any suggestions for the valve train and head?
Old Jun 3, 2007 | 07:11 PM
Orangedragone's Avatar
Default Re: what kind of whp can i expect from all motor sohc? (94civiclover)
what's your base? (motor, car, goal?)
sounds like you need to do a little more searching tho.
as for the title, the most i've seen with a single cam (on this site) was a nice dyno of ~140whp. not much, but enough to make a b16 cry.
Old Jun 3, 2007 | 07:28 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: what kind of whp can i expect from all motor sohc? (Orangedragone)
This question is impossible to answer.
a stock all motor civic? Or a civic with rods, cams, port/polish/ etc etc etc.
Either way, you could give us all the mods, compression tests, oil viscosity, flywheel weight, valve lift duration and we'd still never be able to accurately guess whp or 1/4 mile time.
Old Jun 3, 2007 | 07:45 PM
MJ0LNIR's Avatar
Christ, what's with all these threads all of a sudden?
Nobody can tell you what your hp/1/4 time/torque or whatever will be given certain components. This isn't some equation where you plug in Injen this and Skunk2 that and come up with an answer.
Search the site, find people with similar setups, and ask them.
for laziness.
Old Jun 3, 2007 | 07:59 PM
well i was just wondering if any body had any ideas for it ive been researching for about 4months now and all ive come up with is how to turbo a single cam really just wanna have a good daily driver i can win some races with
Old Jun 3, 2007 | 08:11 PM
MJ0LNIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civiclover &raquo;</TD></TR><TR><TD CLASS="quote">well i was just wondering if any body had any ideas for it ive been researching for about 4months now and all ive come up with is how to turbo a single cam really just wanna have a good daily driver i can win some races with</TD></TR></TABLE>
Ok... so if you've been doing your homework, then you know that building a single cam yields limited results at best, and that boosting it is much more bang for the buck, and can be done very reliably for a DD.
/thread
Old Jun 3, 2007 | 08:12 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civiclover &raquo;</TD></TR><TR><TD CLASS="quote">i just wanna have a good daily driver i can win some races with</TD></TR></TABLE>
turbo, tune, end of story.
A fast n/a d-series sohc won't be fun to daily.
Old Jun 3, 2007 | 08:18 PM
Default Re: what kind of whp can i expect from all motor sohc? (ek forever guy)
right but what about my high comp pistons will i still be able to run boost with suck hi comp 11.3 to 1 and also can i supercharge it intstead?
Old Jun 3, 2007 | 08:21 PM
Ek Forever y0!
Of course you can super-charge it, but why? To be different?
There's a reason 99.9% of small displacement cars that are FI are turbocharged instead of SC.
High compression + boost = detonation.
you want stock or lower compression.
Old Jun 3, 2007 | 08:24 PM
thats why i was going the all motor root instead of boosting it i dont want to change the pistons
Old Jun 3, 2007 | 08:26 PM
Ek Forever y0!
you can safely make 220whp on stock internals and it will still be reliable. And probably get decent mpg depending on your tranny/turbo.
Sounds like you researching for 3-4 months is a lie. What i've told you can be learned in 3-4 minutes on d-series.org
Old Jun 3, 2007 | 09:48 PM
doood's Avatar
been there done that
was that 3-4 months of searching mostly on which i/h/e to get?
spend the money you would going all motor on boost and you'll be much happier with the results if you dont blow something up first.
THE BULL
24
Jun 20, 2009 07:53 PM
hondaspeed305
Dec 11, 2008 05:53 AM
jt-sport
103
Sep 6, 2008 12:08 AM
hondajav06
Sep 20, 2006 09:49 AM
94sohc13
Mar 13, 2004 09:58 PM
