windows roll up so slow..
Old Jun 3, 2007 | 02:21 PM
PhrequenC's Avatar
Default windows roll up so slow..
in my 2000 civic ex,
is there anyway i can speed up the rolling up of my windows?
the windows roll up so slowly, and moderate speed down. is there a way to speed them up?
Old Jun 3, 2007 | 02:24 PM
frankie11's Avatar
Default Re: windows roll up so slow.. (PhrequenC)
it probally is the window regulator. my was really slow and then when I put a new one in my car it was so much faster. you might just be able to lube them up
Old Jun 3, 2007 | 02:27 PM
8krdline's Avatar
i had the same problem on my passenger side. I just sprayed the inside of the moldings with silicon spray and it fixed it.
Old Jun 3, 2007 | 02:30 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: windows roll up so slow.. (8krdline)
Either they have too much friction in the channels, or you need a new regulator.
Silicone spray works wonders like stated before.
Old Jun 3, 2007 | 02:37 PM
Phil_Eg's Avatar
Default Re: windows roll up so slow.. (ek forever guy)
Had the same problem too silicone spray does the job
Old Jun 3, 2007 | 04:40 PM
ATEJ8FTW's Avatar
when you say spray inside the moldings, do you take apart the door panel?
Old Jun 3, 2007 | 04:55 PM
8krdline's Avatar
Default Re: (ATEJ8FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATEJ8FTW &raquo;</TD></TR><TR><TD CLASS="quote">when you say spray inside the moldings, do you take apart the door panel?</TD></TR></TABLE>
no, just spray inside the track where the window slides up
Old Jun 3, 2007 | 04:57 PM
excivicboy96's Avatar
To speed up your windows just get bigger muscles and move faster Mine really hogs down when there is water on the window. But it does an ok speed when dry. Not as fast as my Drivers side.
Old Jun 3, 2007 | 07:19 PM
Ek Forever y0!
Default Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote"> To speed up your windows just get bigger muscles and move faster </TD></TR></TABLE>
OP has power windows.
Old Jun 3, 2007 | 07:58 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote"> To speed up your windows just get bigger muscles and move faster Mine really hogs down when there is water on the window. But it does an ok speed when dry. Not as fast as my Drivers side.</TD></TR></TABLE>
lol just hold the switch harder!
Old Jun 3, 2007 | 09:04 PM
NOFX's Avatar
H-T White Ops
Default Re: (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">lol just hold the switch harder! </TD></TR></TABLE>
That's what I do.
Old Jun 3, 2007 | 09:07 PM
ke98248's Avatar
Default Re: (NOFX)
Be careful where you spray the silicone spray (just within the tracks), cause if you don't, it can get on the visible window itself and smear around.
Old Jun 3, 2007 | 09:08 PM
Ek Forever y0!
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">Be careful where you spray the silicone spray (just within the tracks), cause if you don't, it can get on the visible window itself and smear around.</TD></TR></TABLE>
It wipes off with rubbing alcohol.
Old Jun 3, 2007 | 10:25 PM
nvynuke18's Avatar
Default Re: (ek forever guy)
good thread...i need to do this too. post for bump
Old Jun 3, 2007 | 10:30 PM
cycoclown's Avatar
Default Re: (nvynuke18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
It wipes off with rubbing alcohol. </TD></TR></TABLE>
it will work wonders
Old Jun 5, 2007 | 04:07 AM
PhrequenC's Avatar
Default Re: (cycoclown)
im glad i brought up a touchy subject. does anyone have pics of the process? also, what type of silicone spray or lubricant are we talking about and were can it be found?
Old Jun 5, 2007 | 04:58 AM
Racing rice's Avatar
New User
Honda power windows are pretty notorious for this. I replaced the seal around the window in my Civic and I couldn't believe how much faster the window would roll up and down. Definitely try the lube first. You'll probably be amazed at how much better it works.
Old Jun 5, 2007 | 05:07 AM
perpetualburn's Avatar
How did you replace the seals?
Old Jun 5, 2007 | 11:20 AM
NOFX's Avatar
H-T White Ops
Default Re: (Racing rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing rice &raquo;</TD></TR><TR><TD CLASS="quote">Honda power windows are pretty notorious for this. I replaced the seal around the window in my Civic and I couldn't believe how much faster the window would roll up and down. Definitely try the lube first. You'll probably be amazed at how much better it works.</TD></TR></TABLE>
It's not just power windows. Manual windows have the same exact problems.
I've never heard of it being the seals though. It's always been said to be a problem with lube, the tracks and the regulator. Sometimes the motors on the power windows eventually give out after having to try so hard for so long too.
Old Jun 5, 2007 | 12:01 PM
New User
Default Re: (NOFX)
Over time the rubber seals around the window wear and lose shape which causes the windows to rub more. I wouldn't have thought until I put a new one in. Once you've taken it apart it becomes a little more clear as to why. I'm sure it would be the same thing for the manual windows. I've just never owned a Honda with manual windows before.
Old Jun 5, 2007 | 12:05 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing rice &raquo;</TD></TR><TR><TD CLASS="quote">Over time the rubber seals around the window wear and lose shape which causes the windows to rub more. I wouldn't have thought until I put a new one in. Once you've taken it apart it becomes a little more clear as to why. I'm sure it would be the same thing for the manual windows. I've just never owned a Honda with manual windows before.</TD></TR></TABLE>
I've taken apart both my power window/door and my boyfriend's manual window/door. The power window on my car had no problem with the seals (and Honda ended up replacing the regulator and the car was fine since then). The car with the manual windows has an issue with the seal, but only because the window popped off track and he wasn't willing to put it back on, so it's been sitting with the seal half in and half out.
Old Jun 6, 2007 | 05:53 PM
PhrequenC's Avatar
more help?
Old Jun 6, 2007 | 06:09 PM
NOFX's Avatar
H-T White Ops
Check the parts that usually cause problems:
- Not enough lube on the tracks / bent tracks.
- Bent regulator.
- Dying motor because of resistance caused by the above.
I imagined you've tried lubing the tracks already.
If you can tell something's wrong, replace it. If you can't, bring it somewhere to get it fixed.
Old Jun 6, 2007 | 07:32 PM
PhrequenC's Avatar
Default Re: (NOFX)
how do i get to the tracks?? and what silicone lube should be used??
Old Jun 7, 2007 | 08:52 AM
spotscivic's Avatar
i got the same problem.. all it is just weak window regulators. go to the dealer parts store or ebay sells aftermarket window regulators that are a bit faster then stock. but get name brand the cheap stuff will short out on you and lock up, im shur. good luck
