Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow shock adjustment (w/H&R sport)
Old Jun 3, 2007 | 02:06 PM
Nathan007's Avatar
Default Koni Yellow shock adjustment (w/H&R sport)
I'm about to install my koni yellow on my accord 01 coupe (4cyl)
i was wondering about the adjustments to do on them because the unclear instructions makes me doubt about it..
here are the pics:
My kit! Note; the koni's have the litte white plastic adjustment ***** for them (4)
Now, the wierdo instructions.. Do i adjust like this?
Or like this? (in yellow)
I was told some are adjusted internally, some externally (with the *****), now, how do i differenciate it? It would suck to mount them, install them on the car, only to figure out i have to take them apart to adjust them..
thanks for your imput it will be gladly appreciated
Old Jun 3, 2007 | 02:24 PM
chrisw85's Avatar
If you have the adjusters on top of the shock rods yours are externally adjustable. If you don't have the little tabs, yours are internally adjustable, but there aren't many internally adjustabel Koni Sport 'Yellows' that I know of.
Old Jun 3, 2007 | 04:37 PM
kleen98accord's Avatar
Default Re: (chrisw85)
well check the tab at the very top of the shock. i have them too. the white cap they give you, should adjust them. the front has the tab where you put the key on. i don't know about the rears because i don't have them. if you can't put the white key on the rears, maybe thats how you'll have to adjust them.
Old Jun 3, 2007 | 11:38 PM
Nathan007's Avatar
i'll have to check if i can get them to fit.. last time i stripped the car i found it was pretty tight back there..
thanks for the info
Old Jun 4, 2007 | 10:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
As far as I know the Koni "Red" shocks are internally adjustable. Koni Sport yellow shocks should use the tab on the top of the shock rod. Check under those black plastic caps on the top of the rod. Those are there to protect the adjustment tabs from getting damaged during shipping.
Nathan007
May 20, 2007 09:16 PM
baonest
Aug 4, 2002 12:16 AM
95hbMatt
Jun 24, 2002 10:22 PM
taytay333
Mar 26, 2002 03:54 PM
taytay333
Mar 25, 2002 09:07 PM
