need help misfiring!!!!!!!!!
Old Jun 3, 2007 | 01:45 PM
ek4ferrio's Avatar
Default need help misfiring!!!!!!!!!
hey everyone i have problem this morning i saw my check engine light on and then i checked it out through my ecu and looked in the book on the codes for what was happening well it said that my fourth cylinder is misfiring what could be the problem of it misfiring? trying different stuff right now so any help would be really appreciated thank you!!!!!!!!!!
Old Jun 3, 2007 | 01:59 PM
97Ej6mike's Avatar
It just means your spark plug is dead and isnt getting a good spark. Replace all 4, and you will be fine.
Old Jun 3, 2007 | 02:46 PM
ek4ferrio's Avatar
Default Re: (97Ej6mike)
cool ill try that right now ill post if it still doesn't check right
Old Jun 3, 2007 | 02:56 PM
ridin98civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">It just means your spark plug is dead and isnt getting a good spark. Replace all 4, and you will be fine.</TD></TR></TABLE>
not always true, but its a start.
check for spark, fuel, compression
Old Jun 3, 2007 | 02:59 PM
97Ej6mike's Avatar
Default Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">
check for spark, fuel, compression</TD></TR></TABLE>
Well thats the problem in most cases, otherwise you gotta work your way back, check ignition wires, rotor/cap, wiring of dizzy, grounds, ect. Most likely its just the plug is dead, thats a common reason for a 'misfire'
hondaboy415
10
Dec 9, 2007 03:52 PM
bigislandc2
10
Sep 16, 2007 07:43 PM
eg6cusco10pt
Sep 29, 2005 09:19 PM
95civickid
19
Mar 13, 2005 05:07 AM
jweezy225
Aug 4, 2004 03:17 PM
