FRIED Hondata s200 p75 ECU. HELP ME! What caused it? SMELLS TOASTED!
Old Jun 3, 2007 | 09:43 AM
DXK Eg's Avatar
Default FRIED Hondata s200 p75 ECU. HELP ME! What caused it? SMELLS TOASTED!
Hi guys, finally got done with my build. I bought this Hondata s200 along with the p75 ECU from eBay. Its been sitting for about 3 months or so. I didn't even open it up to look at it. I dont know if I fried it or the orginal owner sold me a F***ED UP ECU. Well my question is, WHAT COULD OF CAUSED THIS AND WHAT ARE THE CHANCES THAT IT DAMAGED THE HONDATA S200? AND CAN THIS BE FIXED OR DO I NEED A NEW ECU?
Ohh yeah and it has Q31 and E next to the BURNT thing.
Old Jun 3, 2007 | 09:48 AM
turtleman321's Avatar
let me check mine but i did the same. you mixed up 2 connectors on your engine. iscrewed up IAT and IACV. let me host some pictures of mine.
Old Jun 3, 2007 | 09:56 AM
i was told by the guy at phearable to cut it off and that is what i did. no problems at all its just some stupid diagnostics bs.
here is mine cut off. sorry for the shitty picture my dad took it.
Old Jun 3, 2007 | 10:05 AM
DXK Eg's Avatar
Default Re: (turtleman321)
Did your car start after you cut it off?
Old Jun 3, 2007 | 10:09 AM
pmed you back, but yes now problems and its been 6 months
Old Jun 3, 2007 | 05:41 PM
Blown90hatcH's Avatar
Default Re: FRIED Hondata s200 p75 ECU. HELP ME! What caused it? SMELLS TOASTED! (DXK Eg)
That is normally caused by switching the IAT and IACV wires/connectors on the engine harness. The ecu will still function with no codes if this is the case.
Old Jun 3, 2007 | 07:39 PM
Jim Truett's Avatar
Default Re: FRIED Hondata s200 p75 ECU. HELP ME! What caused it? SMELLS TOASTED! (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">That is normally caused by switching the IAT and IACV wires/connectors on the engine harness. The ecu will still function with no codes if this is the case.</TD></TR></TABLE>
That is the EVAP Purge driver. It is caused when the EVAP purge plug is connected to the IAT sensor or the IACV.
If it was connected to your IAT sensor, it is most likely melted and no longer functional. If you are tuning with the S200, datalog the session and verify that the IAT value is tracking correctly. If the value doesn't change, the sensor is bad.
EGtoua
Engine Management and Tuning
Apr 28, 2010 03:28 PM
B18c1turboedEK
Aug 18, 2005 02:26 PM
Duck Sauce
Nov 23, 2001 04:06 AM
