Suspension & Brakes Theory, alignment, spring rates....
Problem with lower ball joint rubbing brake.
Old Jun 2, 2007 | 09:54 PM
Civichatch2k's Avatar
Default Problem with lower ball joint rubbing brake.
Ok, like the title says I am having a problem with my lower ball joint and nut rubbing against the brake disc when I turn right. It is the driver side. I have adjusted the ride hieght and still no luck..
I have upgraded the brakes with 10.5 del sol brakes. I really would like any input on how I can correct this problem.
The car is a 00 EK hatch...any other info needed please let me know I will provide it.
thanks.
Old Jun 8, 2007 | 10:45 PM
Default Re: Problem with lower ball joint rubbing brake. (Civichatch2k)
ttt.
come on guys. sure someone has had a problem with this before. Please any information would be very helpful.
Old Jun 10, 2007 | 08:37 AM
hayabusa160's Avatar
sounds like something is bent.
Old Jun 10, 2007 | 11:12 AM
Default Re: Problem with lower ball joint rubbing brake. (hayabusa160)
That is actually what I was thinking as well.
I am getting ready to replace the lower control arms with Si ones so I can run a sway bar and I will post if that corrected it.
Thanks.
Anyone else?
Old Jun 10, 2007 | 04:05 PM
ED9man's Avatar
Bend the heat shield out of the way
Old Jun 10, 2007 | 05:14 PM
stumpyf4's Avatar
Does it look like anything in this thread? If so PM the OP and ask him how he fixed.
https://honda-tech.com/zerothread?id=1788276
ElGsRcOoP
Jun 14, 2008 06:09 PM
devney
Nov 20, 2007 07:22 PM
hcben00
Suspension & Brakes
May 21, 2006 09:02 AM
opiumdaze
Oct 11, 2005 09:27 PM
clark kent
Sep 1, 2003 04:52 PM
