ZAPCO SP4-SL EQ can I connect a non zapco amp to it?
Old Jun 2, 2007 | 09:42 PM
Kangolbrand's Avatar
Default ZAPCO SP4-SL EQ can I connect a non zapco amp to it?
I got the eq and notice theres a slot for input and that has rcas while the highs/mids have a s-cable light slot for each and so does the sub... I know zapco amps use that type of plug but can I use other amps that use normal RCAs out with this eq? do I need to buy there symbolinks in to rcas to make it work with my non zapco amps?
Thanks for the help, if you know a place that sells the symbolinks cheap let me know as it looks like ill be needing 3 of them./.... highs/mids/sub
Modified by Kangolbrand at 10:09 AM 6/3/2007
Old Jun 3, 2007 | 06:11 AM
twogengsr's Avatar
Default Re: ZAPCO SP4-SL EQ can I connect a non zapco amp to it? (Kangolbrand)
yes you will need the zapco cables just make sure your amp can handle the signal voltage comming out of the eq
Old Jun 3, 2007 | 09:09 AM
where on my amp specs. would tell me that it can handel the signal voltage comming out of the eq
Old Feb 2, 2010 | 06:17 PM
c|rop3asy==[]'s Avatar
does anyone know waht cables i need to run this eq?
Old Feb 3, 2010 | 06:02 AM
fcm's Avatar
fcm
Old Fart
http://www.zapco.com/prod/signal_pro...ssorManual.pdf
You will have to check with Zapco... http://www.zapco.com/contact.php to see if output cables, [din to RCA] are available.
I do not see any on the Zapco site. 94
Chewy954
Audio / Security / Video
Dec 22, 2008 12:22 AM
Team PHATBOYZ
Mar 28, 2006 07:58 PM
technine
15
Jun 15, 2004 08:04 AM
Bubble Gum Jr.
Feb 11, 2004 06:11 AM
B00STeD
Jan 13, 2004 03:26 PM
