?????????Your opinion on engine rebuild?????????
i have a 94 ls with 130k miles on it, i want to rebuild it to be fast. i want it to be all motor im not into turbo and super and nos. etc. just some raw power. it is my daily driver so take that into consideration. i dont want to do an engine swap or ls/vtec. i just wanted to know what u guys would rebuild it with, what kind of cams, pistons, valves etc. and aprox. how much it would cost with install. ( i dont think i can handle it by myslef) also what kind of numbers do u think i will be running. im lookin for somethin not to expensive im not the wealthiest of people at the moment but im just tryin to get an idea for a rebuild. thanks alot
goto an impound lot and look for a GSR with usable parts, maybe you could find some s2k parts.
[Modified by Jarod, 10:05 PM 6/4/2002]
if you want to have a fast all motor setup adding the Vtec head would be a good idea, some b16 pisonts are a good way to raise the compression and not that expensive and some ITR or CTR cams will yield nice power. or if you want to be more aggressive get some forged internals do 12:1 compresion and get some stage 2 or 3 cams and the apprepriate valvetrain.
goto an impund lot and look for a GST with usable parts, maybe you could find some s2k parts.
i know it wasn't one of your suggestions, but if you're going to spend a lot of money rebuilding, why not just swap it out for a vtec motor--it's got more potential. selling your ls motor will offset cost a little. just my opinion.
What was wrong with that post? You can pick up a lot of cool stuff and a junk yard...you need to chill out man. I dont know what happens..I registered here a long time ago, and it always makes my post count lower..plus, im not my post count, computer specs, or my cars modifications..so i dont care how low my count is. thanks for your concern though
haha..whatever man, whatever.
Grow up man. Nobody wants to hear about how you "used to want a teg", or how you're smarter than all the teg ricers now, or how you're gonna get a car with a rotary engine and show all us punk ricers what is up
Man, get a life.
Justin
Anyway........... I agree you can probably just get a B16 or a B18C , Engine&head assembly, not worry about building specs, save lots of time and headaches, slap it in, and tune it really nice, maybe add a set of cams later on.
[Modified by One20Two, 12:12 AM 6/5/2002]
where can i find a gsr engine for a decent price, EXACTLY what else do i need to get it into my 94 ls, down to every nut and bolt, i dont have alot of $$$ so would it be cheaper to rebuild my ls tranny with gsr gears??
I think you have a great Idea but, just need some input for you to pusue the project.
I, my self is also going through the stage of rebuild. My 94GSR has over 100,000miles and I'm afraid to go street racing. I know my teg very well and I know its not gonna let me down. But If you abuse it, it will not last.
My suggestion to you is, have it built right the first time. Dont look for cheap way out. Get the best parts that you can get and have it built right. sure it will be costly(it doesn't have to be expensive to be the best parts) but, I know you'll feel better after you take your ride out the first time and see the whole new engine scream! It's great idea to keap the engine as is. dont have to go to GSR head to to beat a GSR. I should know. Not only that, you'll have a strong engine that can easily bolt on turbo's. And the LS is great for that. It is a big project! so take your time and do some research.
juss buy the motor and tranny as a complete package...probably around 3500..jdmhondaparts.com has them..i dont know if that includes shift linkage and ecu tho..ask in best buys forum too. good luck
Going with a gsr motor is a cool idea, but you can build up your ls block for the same aount of money. Going with a B18c1 will require you to run a whole new wire harness and that takes money and experience. I think you should just go with a B20 or a B20Z. If you get a b20 block you could probably use your existing wire harness and just swap the ecu.
Take your stupid comments to SHO or ClubSi
wow dude, no need to be a dick. so what if he was wrong, that's was kinda harsh don't ya think.
[Modified by sean96gsr, 9:17 PM 6/4/2002]
im really only lookin to spend 2k -2.5k on EVERYTHING, what do u think the chances are of finding a used gsr engine for cheap in a junk yard?
here how about this. B20 bottom end ( 900) rebuild the head( not that much at all), crower 404's ( 300$ used or new got my crower 403's for 250$), crower valve springsW/ titanium retaienrs - 300$( or cheaper), cam gears- 150$, FPR ( 40-50$) a lil tuning ( 150) tehrs about .. 1600$ right there, and add a GSR tranny for another 600$ and you got a 2200 LS all motor daily drivable reliable "Torquey" set up.
