Suspension & Brakes Theory, alignment, spring rates....
ok to cut?
Old Jun 2, 2007 | 01:07 PM
b_serious's Avatar
Default ok to cut?
is it ok to cut eibach springs? i have a pro set but the ride height is horrible. i'd like to go another 2 or so because this wheel gap is ugly. and car feels like a truck still.
i know its bad if u cut oem springs because it will bottom out and bounce. will it do the same with aftermarket cut springs?
Old Jun 2, 2007 | 04:19 PM
ThoseDarnKids's Avatar
Default Re: ok to cut? (b_serious)
Cutting any springs will increase the spring rate, meaning the shock allows it to bounce more. You might reduce the wheel gap, but it's not going to ride nice.
Old Jun 2, 2007 | 06:18 PM
PianoMan's Avatar
+1
You're removing mass to the spring which the designers engineered to match the weight of the car, changing its spring properties.
Buy a set of used Sportlines and sell the Pro's. What shocks are you riding on?
PM
Old Jun 2, 2007 | 07:41 PM
b_serious's Avatar
Default Re: ok to cut? (PianoMan)
new set of eibach pro dampners
Old Jun 3, 2007 | 01:15 PM
503_EF9's Avatar
dont some springs have "dead coils" that are meant to be cut for adjustmeant in ride hight without adjustable coilover kits?
Old Jun 3, 2007 | 01:17 PM
b_serious's Avatar
Default Re: ok to cut? (dylan_surrender)
eibach pros dont have dead coils =/
Old Jun 3, 2007 | 07:58 PM
503_EF9's Avatar
oh. i had no idea it was kinda an all around question do "dead coils" affect the ride quality or are they strictly for height adjustment?
Old Jun 4, 2007 | 10:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Dead coils already have their spring rate at infinite (since they're already touching) and will not affect the spring rate of the active coils at all. I cut dead coils off the rear springs of my old car with no ill effects whatsoever.
If you have high-quality dampers, like Koni Sports, I would say you could cut off 1 or 2 coils (which increases the spring rate if they are active coils) with no bad effects at all. However I think most normal-style lowering springs (which are similar to OEM springs in shape) have smaller-diameter coils at the top or the bottom or both, and they often have the end of the coil flattened to help the spring sit correctly on the perch. If you cut off any of these coils, the spring won't sit correctly on the perch and could shift around while driving.
Old Jun 4, 2007 | 11:12 AM
kleen98accord's Avatar
Default Re: (PatrickGSR94)
i have tein s techs on a 98 accord coupe cyl. The springs have dead coils. Would i be able to cut some off. I want to lower my car a little more. I have koni yellows (sport) in the front and blue tokico blues in the back.
Old Jun 4, 2007 | 11:26 AM
Community Builder
Default Re: (randomvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomvtec &raquo;</TD></TR><TR><TD CLASS="quote">i have tein s techs on a 98 accord coupe cyl. The springs have dead coils. Would i be able to cut some off. I want to lower my car a little more. I have koni yellows (sport) in the front and blue tokico blues in the back. </TD></TR></TABLE>
The only issue if you only cut dead coils is that you might put the rear shocks out of their usable range and cause them to blow out quicker. Koni Sports are pretty good no matter what drop you throw at it, so it wouldn't be a big deal up front.
But like I said before, if the spring's dead coils are on the same end as the end with the flattened coil (usually on the top) then I wouldn't cut any. Depending on the shape of the bottom of the spring where it sits on the lower spring perch, you may or may not be able to cut any. Just look at it and use good judgment.
Old Jun 4, 2007 | 11:42 AM
hmm... better off to get new springs huh?
Old Jun 4, 2007 | 07:25 PM
503_EF9's Avatar
thank
Old Jun 4, 2007 | 08:13 PM
xdc220x's Avatar
Default Re: (dylan_surrender)
just buy new springs... or better yet coilovers. you get what you pay for.
Old Jun 9, 2007 | 02:32 AM
The Si's Avatar
Default Re: (xdc220x)
Cutting the springs will give you a very uncomfortable bouncy ride.
Old Jun 9, 2007 | 04:28 AM
Community Builder
Default Re: (TheSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSi &raquo;</TD></TR><TR><TD CLASS="quote">Cutting the springs will give you a very uncomfortable bouncy ride. </TD></TR></TABLE>
not with good quality shocks. Only with stock shocks would a cut spring blow them out.
sohcpoweredeg
33
Sep 22, 2011 05:36 AM
oblivion2kx
Sep 27, 2008 11:42 PM
kevinm1981
Mar 28, 2004 07:33 AM
88turdbucket
Jan 25, 2004 07:42 AM
PnX-R
Apr 27, 2002 03:02 PM
