Im new to rexs...I need help
Please help
I had a GSR but it just got stolen and the thief wrecked it. I want another one but since Im about to go to college Im trying to cut costs. I was wanting to get a CRX because I can get one cheap and it gets good mpg. I found 2 in my area and since I know nothing I was wondering if you guys could help.
Here are the ads
1989 Honda CRX Si,
Runs great, new timing belt and water pump, new brakes, $2500
I called on this one and the guy says the clutch is good, tires are new, new front and rear speakers, and it has 180,000mi
Sounds like an older guy
next,
1988 HondaCRX, High flow good running car, new timing belt new cat, exhaust, short ram intake, but it has a bent rack and pinon, 185kmi $1800
are these good or bad
Here are the ads
1989 Honda CRX Si,
next,
Definately the Si. I'd bet money the '88 is a DX.. which is DPFI and considerably slower. Not that speed is your big issue starting college, but you'd at least be able to get up to freeway cruising speed without having to floor the petal.
I don't know...180k...that's a lot, yeah it may be an older guy...but find out if he's the second owner...and if it has rust...especially holes...2500 is kinda high...also look under the hood, make sure everything lines up right...in case it was in a wreck...I bought mine wrecked and didn't know till later that it had been wrecked once already so some parts don't line up quite right...but then again I got my Si for 200 bux...164k...and I live 2.5 hours from home and go there more often than some...good luck
Well I went and looked at it. It looks pretty clean on the inside other then needing a good vacuuming, the exterior has some oxidation and of course the sun roof paint is meesed up the car in general is looks good to me. The only thing is that it needs a new AC pump and the clutch feels like it will need to be replaced in the next 1000mi. As far as I.C.E. goes it has new speakers all around and sony CD player. THe guy has owned it for atound 6 months he bought it from the first owner who used it to commute to the atlanta airport and back about a 60mi one way drive. Motor runs good and has a new exhaust
Here is the CARFAX-the first record carfax has it at 99K miles, interesting.
On the clutch I thought I had the same problems with mine(I got it 3 weeks ago)but it turned out that I just needed to readjust the clutch cable, look into it.
GOOD NEWS! CARFAX search results confirm this vehicle (JHMED9363KSOO5634) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Section #: Section Name: Section Results:
Vehicle Specifications JHMED9363KSOO5634
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 2 Total Vehicle History Records Found
Register your FREE $5,000 CARFAX Clean Title History Guarantee Today!
NOTE: This vehicle has not been inspected by CARFAX and it may have problems that have not been reported to CARFAX. CARFAX recommends a vehicle inspection by a professional mechanic.
How did CARFAX analyze this vehicle's history?
VIN: JHMED9363KSOO5634
GOOD NEWS! CARFAX search results confirm this vehicle (JHMED9363KSOO5634) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this vehicle (JHMED9363KSOO5634) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
05/28/1996 99,518
GOOD NEWS! CARFAX search results on this vehicle (JHMED9363KSOO5634) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
CARFAX search results on this vehicle (JHMED9363KSOO5634) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The CARFAX database contains a total of 2 vehicle history records on this vehicle (JHMED9363KSOO5634):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
05/28/1996 99,518 Georgia
Inspection Station
Atlanta, GA
Passed emissions inspection
05/28/1996 Georgia
Inspection Station
Atlanta, GA
05/28/1996 99,518
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Inspection Station
Atlanta, GA
05/28/1996 Georgia
Inspection Station
Atlanta, GA
THanks Alot Im going to try and get it if I get the Ins. money in time.
Im going to offer him 2000$. Does that sound like a reasonable offer? I looked up the blue book and it is $1995.00.
good choice with the si, but talk his *** down. i picked up my 90 crx with 116mi for $2000. and its in exellent shape plus you said the guy sounded old so it will be easy to talk him down.
this is Vuse1, posting under my friends name
[Modified by khoalie, 9:04 PM 6/5/2002]
grilledcheese33
13
Nov 5, 2006 04:34 PM
merdoc
Oct 31, 2004 07:55 AM
