Cluster Wiring??
Old Jun 1, 2007 | 11:46 PM
143MYVTECEF's Avatar
Default Cluster Wiring??
Ok so i was going to swap my 1989 Civic hatch DX cluster for a 90 or 91 Si cluster and when i examied the back of the cluster i noticed my DX cluster only has 2 plugs but the Si cluster has 3 plugs. Two of the plugs look similar to both the si and dx but the third plug on the Si is small and only has like four wires.. Now what is the purpose of the third plug. Any help would be sweet
Old Jun 2, 2007 | 04:09 PM
Default Re: Cluster Wiring?? (143MYVTECEF)
Need some help
Old Jun 3, 2007 | 01:52 AM
Bump for help please..
Old Jun 3, 2007 | 11:48 AM
blksheep6's Avatar
If I remember correctly the DX does not have a tach on the cluster. that plug is problably what runs the tach. don't quote me doh
Old Jun 3, 2007 | 12:06 PM
B16CRXT's Avatar
Default Re: Cluster Wiring?? (blksheep6)
that third plug is insignificant from what I've read. When I put a gsr cluster in my 91 si crx, it had one of the small plugs on it also, but everyone said not to mess with it. It is for things not used on the gsr cluster....no idea what it is for on the rex.
Old Jun 3, 2007 | 03:44 PM
Default Re: Cluster Wiring?? (B16CRXT)
**** well im still clue less on what it does and if its even needed.. Someone fill me in
Old Jun 3, 2007 | 06:42 PM
Bump
Old Jun 3, 2007 | 07:30 PM
jdmd15bciviconrice's Avatar
look around the site ive posted a link of the difference between the two it has pics and info on each wire and theres a pic of it some where too......so just look around?
Old Jun 4, 2007 | 12:27 PM
Default Re: Cluster Wiring?? (jdmd15bciviconrice)
Dude I've looked around and seen all those diagrams.. Obviously reading > you because i know how to wire a cluster up im asking about the third blue connector and what its purpose is
Old Jun 4, 2007 | 07:58 PM
melloman's Avatar
zzzzzzz. I just swapped a Si cluster into my DX. But as far as I knew, 89 DX can ONLY swap for a 89 Si because of this 3rd plug. And yes B16CRXT would be correct then, the 3rd plug does f*ck all. 89 DX to 89 Si is straight swap.
gl
-mello
Old Jun 4, 2007 | 09:51 PM
Default Re: Cluster Wiring?? (melloman)
So i can only swap to the 89 Si cluster becuse of the lack of the third blue plug correct?
Old Jun 5, 2007 | 08:54 PM
melloman's Avatar
meh try it anyway with the 91 cluster and see what happens. I've always done 89-89 swaps though because that's what I have learnt. Might as well try it, not like your car will blow up.
-mello
Old Jun 5, 2007 | 10:19 PM
haha true true.. but if anyones selling a 89 si cluster with the two plugs let me know
Old Jun 9, 2007 | 04:22 AM
B16CRXT's Avatar
it didnt effect anything on mine. I dont even have it plugged up on my gsr cluster, but it fits in the hole fine. Just go with it.
91EFH22
13
Jan 3, 2012 12:01 PM
hondanator88
18
Oct 30, 2010 04:10 PM
Mr.Meowsome
12
Dec 4, 2007 05:23 PM
Vaans
Aug 27, 2004 05:21 PM
Speedfreak
Dec 11, 2002 04:43 PM
