is this good for lowering a 96 civic ex coupe?
http://www.racinglab.com/skunk2-coilover-010.html
-Tokico HP shocks with Springs
or
-Tokico HP shocks with tein s-tech springs?
Modified by ShinotakuX at 12:19 PM 6/2/2007
or
You can buy those Skunk2 C/O's along with some Koni, KYB, or Tokico shocks. I must warn you though, I have those C/O's along with some 4way KYB AGX's and the ride is stiff as hell.
ME X2! I have a set of SKN2 Sleeve type w/ Tokico Illumina's on the lowest setting and its pretty damn stiff for street driving, unless u plan on doen autoX
good for lowering. bad for ride quality. if you want a good ride go with soild springs. a coil over like that has a very weak short spring and a weak sleeve. the car will bounce over every little bump. good luck tho. skunk 2 is where its at.
