D16Z6 New head installed alittle chatter.
Old Jun 1, 2007 | 07:07 PM
Exploziveaf1's Avatar
Default D16Z6 New head installed alittle chatter.
I think it the valves are off would that cause a bit of ticking, in the head. I know its not the pistons just installed them
Old Jun 1, 2007 | 07:14 PM
NOv8IV's Avatar
Default Re: D16Z6 New head installed alittle chatter. (Exploziveaf1)
check valve lash...if the lash is set properly and it still does it, check the A/F ratio. I have been dealing with this recently as well. set it as close to .007" intake as possible and .009" exhaust. Don't get it ridiculously tight, it's just a feeler guage. My z6 head seems to be less "clattery" with more fuel. A respectable engine builder nearby says it's pinging making the sound (due to too lean)...but doesn't sound quite like a ping to me, but then again I'm a noob. Runnin a tad on the rich side it seems happy.
Old Jun 1, 2007 | 07:17 PM
NOv8IV's Avatar
Default Re: D16Z6 New head installed alittle chatter. (NOv8IV)
Old Jun 1, 2007 | 07:18 PM
yeah sounds more like a ticking sounds like the values hitting the value cover dosent it, do the bolts holding down the lifter arms need 2 be torqued down 2 a certain pound, the guy i got the head from took it off for some ******* reason i don't know why
Old Jun 1, 2007 | 07:19 PM
Dude if u PM ME your number i will give u a call tomaro when i crank it and let u hear it and u tell me if thats it or not
Old Jun 1, 2007 | 07:25 PM
NOv8IV's Avatar
uhmmm, the tappets' range of "proper operation" for intake is .007" - .009" intake side, and .009" - .011" exhaust. The nut holding the screw needs to be torqued to 20NM or 14.7512429 lb-ft. Remember to hold the screw positioning while torquing the outer nut...otherwise you will just be resetting lash over and over and get pissed and throw things and curse and kick your car.
Kick car = no bueno =
hope this helps in some way.
Old Jun 1, 2007 | 07:27 PM
Alright it shoudent be harder than changing my head, LOL every manual i read didn't tell me about the metal plate holding the intake manifold to the block and i was getting pissed LOL
Old Jun 1, 2007 | 07:53 PM
bsclywilly's Avatar
If that noise isn't your valves, it could also be your fuel injectors switching open and closed which is a normal noise. Sounds like a fast steady clicking/ticking. Some injectors are louder than others.
Old Jun 2, 2007 | 05:42 AM
dont think itsthe injectors i just put some Rc's in there LOL hope not or i will take them back, ill get them checked tho thanks man
Old Jun 2, 2007 | 07:59 AM
bsclywilly's Avatar
If it is, don't take them back. It's a normal noise for the solenoid in the injector to make as it moves back and forth.
sicccc
Oct 26, 2010 05:18 PM
LS_DON4500
Aug 3, 2010 03:47 PM
gnar kill
Oct 14, 2005 11:12 PM
Sinner
May 22, 2005 06:36 PM
dubbedcorde
12
Dec 11, 2004 02:18 PM
