Car shut off and wont start??? Distributor???
Old Jun 1, 2007 | 01:17 PM
DIS-1's Avatar
Default Car shut off and wont start??? Distributor???
I was driving my car down the street when it shut off. Me and my friends started to check it out and came to the conclusion that the engine isnt getting any spark. We put in a new distributor and nothing. Any suggestions what else it might be??? Any help would be greatly appreciated! Thanks!
Old Jun 1, 2007 | 01:19 PM
dannis.'s Avatar
Default Re: Car shut off and wont start??? Distributor??? (DIS-1)
Check the spark plugs, wires, and battery.
Old Jun 1, 2007 | 01:20 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIS-1 &raquo;</TD></TR><TR><TD CLASS="quote">I was driving my car down the street when it shut off. Me and my friends started to check it out and came to the conclusion that the engine isnt getting any spark. We put in a new distributor and nothing. Any suggestions what else it might be??? Any help would be greatly appreciated! Thanks! </TD></TR></TABLE>
no offense, but how did you come to the conclusion that the motor wasn't getting spark?
Old Jun 1, 2007 | 01:24 PM
DIS-1's Avatar
Default Re: Car shut off and wont start??? Distributor??? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
no offense, but how did you come to the conclusion that the motor wasn't getting spark?</TD></TR></TABLE>
We checked by pulling the spark plug out of the head but still having it connected to the spark plug wire and we cranked the car. There wasnt any spark shoting off of the plug
Old Jun 1, 2007 | 01:34 PM
rebel842001's Avatar
did you have the sparkplug grounded by touching the threads of it to a metal part of the engine? cause if you didnt your not gonna have a spark. so you might want to retry the test making sure the plug is grounded. im gonna give u a heads up that all you want to be holding in to is the plug wire when the motor is being spun over otherwise you might get shocked by the ignition sytem it dont really hurt but it will scare the sh*t out of you if your not expecting it
Old Jun 1, 2007 | 01:42 PM
DIS-1's Avatar
Default Re: Car shut off and wont start??? Distributor??? (rebel842001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebel842001 &raquo;</TD></TR><TR><TD CLASS="quote">did you have the sparkplug grounded by touching the threads of it to a metal part of the engine? cause if you didnt your not gonna have a spark. so you might want to retry the test making sure the plug is grounded. im gonna give u a heads up that all you want to be holding in to is the plug wire when the motor is being spun over otherwise you might get shocked by the ignition sytem it dont really hurt but it will scare the sh*t out of you if your not expecting it </TD></TR></TABLE>
Yeah I had the sparkplug grounded. Thanks!
Old Jun 6, 2007 | 01:01 PM
DIS-1's Avatar
Old Jun 12, 2007 | 06:52 PM
z crx z vtec z's Avatar
did you check the timing belt?
Old Jun 12, 2007 | 07:00 PM
93baggedcivic's Avatar
im haveing the same problem i cant figure out what is wrong with it.i just rebuilt the motor and dropped it in i checked spark tot he block to and i didnt get nothing i put a new cap and rotor and now it is trying so hard to crank over but it just wont
Old Jun 12, 2007 | 07:20 PM
Default Re: Car shut off and wont start??? Distributor??? (93baggedcivic)
maybe the igniter
Old Jun 19, 2007 | 08:13 AM
DIS-1's Avatar
Default Re: Car shut off and wont start??? Distributor??? (z crx z vtec z)
Old Jun 19, 2007 | 08:34 AM
bpkmrtoes's Avatar
did u hit a bump or sumthing, so the car cranks? but wont turn over?
Old Jun 20, 2007 | 01:40 PM
DIS-1's Avatar
Default Re: Car shut off and wont start??? Distributor??? (bpkmrtoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes &raquo;</TD></TR><TR><TD CLASS="quote">did u hit a bump or sumthing, so the car cranks? but wont turn over?</TD></TR></TABLE>
Car cranks but wont turn over...
halocore
Jan 8, 2010 04:20 PM
intgraCA
Jul 27, 2006 09:12 AM
ILOVEGIRLS
Apr 19, 2006 07:52 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
