What wiring harnesses can I use?
Old Jun 1, 2007 | 10:16 AM
NegativeXero's Avatar
Default What wiring harnesses can I use?
I have a '97 Civic DX that I'm putting a built B16A in. I took out the wiring harness from before because it was just a mess and there were bare wires everywhere and some didn't work. My question is, what wiring harnesses can I use that will plug right up to my B16A? I have a P2T OBDII ECU. Can I use a wiring harness from a 96-00 EX?
Old Jun 1, 2007 | 10:20 AM
BlueIntegraBoy's Avatar
Default Re: What wiring harnesses can I use? (NegativeXero)
96-98 EX harness with some modifications
Old Jun 1, 2007 | 10:31 AM
ek4_b16a's Avatar
shoulda just kept the stock harness in and just add necessary wires...but since you took it out, just get a 96-98 civic ex harness and use that...get an obd2a to obd1 conversion harness and get a p28 chipped to run the b16...or just get an obd2a to obd2b harness and just use that ecu you have there...should've kept it simple and just reuse your old harness and add on what was needed...but good luck to you
Old Jun 1, 2007 | 10:37 AM
Default Re: What wiring harnesses can I use? (ek4_b16a)
well i still have it, i guess i'll just fix it up and put it back in the way it was.
all4show97
Nov 6, 2005 01:44 PM
phthalo
Jun 18, 2004 10:45 AM
seerxsi
May 10, 2004 06:07 PM
jcivic
Mar 1, 2003 06:16 PM
TheBestCRX
Jan 28, 2003 07:08 AM
