NEED HELP ASAP!! crack block symptoms... (hope not!!)
Old Jun 1, 2007 | 08:58 AM
crazykamper's Avatar
Default NEED HELP ASAP!! crack block symptoms??? (hope not!!)
recent swap we did on buddy's hf crx, swapped in a d16a6 with high comp pistons, it was running great and VERY strong except for idle being jumpy for the past week, we put about 600miles on it already, and changed oil ect...., this mornin he drove it to class, and said that there is water coming out of his exhaust tip after driving the car.... could it be that the block has cracked? or what has happened.... the idle is still jumpy as it was previously....need help asap. thanks!!
Modified by crazykamper at 10:23 AM 6/1/2007
Old Jun 1, 2007 | 09:23 AM
bump! need help please!
jlicrx's Avatar
Default Re: NEED HELP ASAP!! crack block symptoms... (crazykamper)
sounds to me like it is just condensation, which is normal - unless it is a lot of water
Old Jun 1, 2007 | 09:24 AM
is there anyway that it could be that the block is the culprit??
Old Jun 1, 2007 | 09:29 AM
jlicrx's Avatar
Default Re: (crazykamper)
doubt it - the only way to get water into the exhaust is with cracked head or blown headgasket - cracked head or blown headgasket would also have water in the oil
Old Jun 1, 2007 | 09:35 AM
oh, ok, thanks very very much! (sigh of releif)
Old Jun 1, 2007 | 09:59 AM
janz3n's Avatar
there would also be a big cloud of white smoke that willl fill the streets and not go away for a wile.
Old Jun 1, 2007 | 10:50 AM
^ would that be from the water in the oil or?? thanks
Old Jun 1, 2007 | 10:59 AM
jlicrx's Avatar
white smoke out the exhaust is actually steam from water getting into the hot combustion chambers
Old Jun 1, 2007 | 11:00 AM
DenzComp's Avatar
If the oil isn't milky you're probably fine.
Old Jun 1, 2007 | 11:21 AM
oh, i see... what way can i check if oil is milky without draining it?? cause it has gone through literally only 30 miles since we changed it... and dont wanna go out and buy synthetic all over again... thanks!
Old Jun 1, 2007 | 12:04 PM
jlicrx's Avatar
take the valve cover off - if it has water in the oil, it will like like someone poured milk into it
Old Jun 1, 2007 | 12:10 PM
DenzComp's Avatar
Checking the dipstick will work too normally.
Old Jun 1, 2007 | 12:21 PM
janz3n's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">white smoke out the exhaust is actually steam from water getting into the hot combustion chambers</TD></TR></TABLE>
ya, my point is, if water is dripping out of your exhaust , its most likely not coolant because it would smoke not drip out.
Old Jun 1, 2007 | 01:18 PM
thing is, no coolant, its cali... its just water in the rad.... lol. the swap was just done, so we are using water still cause all rad hoses keep slowly bursting...
Old Jun 1, 2007 | 03:12 PM
janz3n's Avatar
it would still smoke and not just drip out. when water hits somethign hot(exhaust) it creates steam.
Old Jun 1, 2007 | 03:43 PM
hmm... interesting... hopefully its just the headgasket...
Old Jun 1, 2007 | 03:49 PM
abnaasefmb's Avatar
Is it smoking or just dripping water? Water is a natural byproduct of combustion that why your exhaust system will rust out before anything else.
Old Jun 1, 2007 | 04:38 PM
ah, i see.... so everything should be normal then?? right on... thanks! saved buddy from buyin new head gasket...
Old Jun 1, 2007 | 09:50 PM
si90rex's Avatar
you said it was idle hopping, ur iacv will cuz this if ur low on coolant.
Old Jun 1, 2007 | 09:55 PM
hmmm. we top off the water/coolant before the car ever gets hot... so dont know about that one...
another thing though is that the oil light comes on soon as the idle goes below 1k, it goes on, and soon as you hit 1k idle, the light turns off.... there have been a few times where the idle just dropped and the car shut off...
Old Jun 2, 2007 | 06:32 AM
white90rexsi's Avatar
Like everyone says if you where burning water/coolant it would be smoking, not driping out. If you want to know for sure you could have a leak down test done on each cylinder. It is liks a compression test except it fills your cylinder with air and measures how much air is escaping, and where it is escaping to. As far as the oil light you could have many diffrent problems. It couls be a dent in the oil pan, a cloged oil pickup, bad oil pump, un-clearenced bearings during the rebuild, faulty pressure switch, etc.
-Chris
Old Jun 2, 2007 | 02:26 PM
buddy just checked the oil, the oil is a milky and has a bunch of white stuff on edges he says.... any input??? would just swapping the headgasket help anything? or is it most likely block/head?? thanks.
Old Jun 2, 2007 | 02:53 PM
njn63's Avatar
Pull the head and have it pressure checked along with checking the surfaces to make sure it's not warped. Then put a new head gasket on.
I'd double check the dipstick along with the oil cap before going through that trouble though just to make sure it is milky. It should look almost a carmel color.
The block is almost never the culprit in situations like this. Only thing that could be wrong is the surface not being straight.
Old Jun 2, 2007 | 03:21 PM
CCCP-ef's Avatar
Default Re: (njn63)
there is none of the white stuff on the dipstick
