obd1 conversion question
Old Jun 1, 2007 | 08:49 AM
haroldthefly91crx's Avatar
Default obd1 conversion question
i know i need a an ECU, a jumper harness, re-wire the distributer and hook up the vtec...
my question is, what sensors and other things to i have to re-wire?
Old Jun 1, 2007 | 09:22 AM
jlicrx's Avatar
Default Re: obd1 conversion question (haroldthefly91crx)
are you swapping to a VTEC engine?
Old Jun 1, 2007 | 09:29 AM
B Series JuNky's Avatar
Default Re: obd1 conversion question (jlicrx)
well if ur car is dual point they would have to convert that to 4 injectors, and dont forget about ur o2 sensor has to be wired up and knock sensor
Old Jun 1, 2007 | 09:41 AM
Default Re: obd1 conversion question (B Series JuNky)
no my car is milti point, (90 crx hf with an si motor and tranny) and i am planning on putting a b16 obd0 in it.
so far my to do list is....
ecu and jumper harness
distributer and re-wiring
4 wire O2 sensor
vtec wiring
what about the alternator and starter?
Old Jun 1, 2007 | 10:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haroldthefly91crx &raquo;</TD></TR><TR><TD CLASS="quote">no my car is milti point, (90 crx hf with an si motor and tranny) and i am planning on putting a b16 obd0 in it.
4 wire O2 sensor
vtec wiring
what about the alternator and starter?</TD></TR></TABLE>
add this on ur list if u dont have it
b series axles non abs-90-91 integra
b series linkage for crx
b series halfshaft 90-93
b series rear T bracket-90-93 integra
b series motor mount kit
b series thorrtle body cable-90-93 integra
Old Jun 1, 2007 | 11:49 AM
HondaPartsHero's Avatar
Technical Hero
alternator and starter will plug right up. you'll need an OBD1 distributor with a distributor adaptor. You can just reuse the injeectors from the B16A. Also will need an OBD1 header for correct O2 placement. You'll need wiring for VTEC solenoid, VTEC pressure switch, and knock sensor.
boosted97civic
Mar 19, 2007 04:32 PM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
SI_Ro
Dec 13, 2003 01:49 PM
crx1856
May 30, 2003 03:29 AM
