Tapping oil return
Old Jun 1, 2007 | 07:42 AM
Rob97'SH's Avatar
Default Tapping oil return
Has anyone tapped their oil return on an H22 Aluminum oil pan. I was surprised to see my stock pan is aluminum. Was going to buy a moroso pan but with my ATTS it doesn't look like I have room. Any leak problems with tapping the pans or is it better to have a bung welded on?
Old Jun 1, 2007 | 08:49 AM
Boilermaker1's Avatar
mine's not an H22, but it is aluminum. I would definitely weld a bung into aluminum. the pan wall isnt that thick, and aluminum is soft enough you may pull the threads out.
Welding is leak proof.
RCautoworks's Avatar
Default Re: Tapping oil return (Rob97'SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob97’SH &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone tapped their oil return on an H22 Aluminum oil pan. I was surprised to see my stock pan is aluminum. Was going to buy a moroso pan but with my ATTS it doesn't look like I have room. Any leak problems with tapping the pans or is it better to have a bung welded on?</TD></TR></TABLE>
We always weld a bung on, this way if you ever take the turbo off you just plug it up.
Old Jun 1, 2007 | 09:03 AM
Mikey3000's Avatar
Default Re: Tapping oil return (RCautoworks)
i think externally threaded bung is the best way to go if room permits.
Old Jun 1, 2007 | 10:47 AM
EJ1 wilcox's Avatar
Default Re: Tapping oil return (Mikey3000)
I'm using a bulkhead fitting on my oil pan. No welding, and has never leaked a drop. Cheap and easy to install, and hassle free.
ymerejOG
May 9, 2018 08:30 PM
Prudz_lude
Oct 20, 2009 10:18 AM
92 CIVIC HATCH VX
Jun 3, 2006 08:19 AM
Aaron.Hillman
Mar 3, 2004 09:02 AM
Mighty Mintos
May 24, 2003 11:49 AM
