what around the fuel rail/fuel injectors could make a whinnnning noise?
Old Jun 1, 2007 | 06:44 AM
mattsnooz's Avatar
Default what around the fuel rail/fuel injectors could make a whinnnning noise?
the whinning is strongest at idle. its occasional, and seems to come from around the far right fuel injector when looking at motor from front. its not like a belt squeeking, could an injector make that noise? the noise fluctuates with rpm as well. checked for vacuum leaks. can't find any. but its not a whistling so i don't think its vacuum/air related. any ideas? Car sputters or misfires at idle only aswell so its most likely fuel /injection related i believe. other wise car runs amazing.
Old Jun 1, 2007 | 09:22 AM
mattsnooz's Avatar
Default Re: what around the fuel rail/fuel injectors could make a whinnnning noise? (mattsnooz)
please bump. could it be water pump?
Old Jun 1, 2007 | 10:00 AM
AndyD's Avatar
I would guess it is one of the injectors if there isn't a vacuum leak.
Old Jun 1, 2007 | 10:05 AM
mattsnooz's Avatar
Default Re: what around the fuel rail/fuel injectors could make a whinnnning noise? (AndyD)
could the injector whine or flutter making a whinning noise?
thanks in advance
Old Jun 1, 2007 | 10:07 AM
AndyD's Avatar
Yup. It's somewhat common issue. Injectors sometimes whine. It can sometimes be a sign that one is about to go bad, too.
Old Jun 1, 2007 | 10:15 AM
mattsnooz's Avatar
i have rough idle situations aswell, which would also be another explanation. Change all four injectors? clean them? or just replace the one? Or do you have any other advice?
thanks alot man!
Old Jun 1, 2007 | 11:08 AM
zirac50's Avatar
take each plug/connector of the injector on at a time, you should hear a reaction (idle would be really rough) by the time you unplug each of them. If there is no reaction by the unplugging FI #1 connector den possibly injector is bad or wiring.
Old Jun 1, 2007 | 11:20 AM
AndyD's Avatar
Default Re: what around the fuel rail/fuel injectors could make a whinnnning noise? (zirac50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zirac50 &raquo;</TD></TR><TR><TD CLASS="quote">take each plug/connector of the injector on at a time, you should hear a reaction (idle would be really rough) by the time you unplug each of them. If there is no reaction by the unplugging FI #1 connector den possibly injector is bad or wiring.</TD></TR></TABLE>
You only need to replace the one that's making the sound.
Old Jun 1, 2007 | 05:40 PM
mattsnooz's Avatar
so im safe to unplug injector connectors while car is running? untill sound goes away ??
Old Jun 1, 2007 | 07:38 PM
m00nr0ck Si's Avatar
Check your pcv also...Mine has made a whining noise when it was clogged...
Old Jun 1, 2007 | 10:44 PM
zirac50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">so im safe to unplug injector connectors while car is running? untill sound goes away ?? </TD></TR></TABLE>
Yes but not too long. I would not take them off for a long period of time. When you take each of them at a time, and you get what you need plug it back in (connector) as possible don't let the engine runs where there is only 3 injectors running for long period of time. That's only my opinion.
Old Jun 2, 2007 | 04:04 AM
mattsnooz's Avatar
cool, right on.
pcv was change already and is opperating perfectly.
ill try injector, im already 99.99999375% that its the number 1 injector, or something leading up to it.
thanks everybody, ill check that #1 injector out.
peace guys!
SKYLINE GT
Dec 1, 2007 05:04 PM
RockLee`
Oct 10, 2006 09:01 AM
jdmcraze
Jun 30, 2004 05:05 PM
zseeanz
Mar 23, 2004 02:26 PM
blu_si
Nov 17, 2002 01:57 PM
