Strange noise after boosting?
Old Nov 17, 2002 | 09:28 AM
blu_si's Avatar
Default Strange noise after boosting?
Hey guys, last night I made a run, only boosted to 8psi, however after that run the car started to jump around at idle. Now i was thinking ok it's just a vacuum leak. Well I pulled into a very well lit gas station and couldn't find any disconnected vacuum hoses. However i did notice that the rubber seals on my injectors were falling apart(WTF?) and the injector closest to the driverside could move (twist back and forth). Where can I get new seals, the injectors are 550 rc's. Also the hissing noise is coming from some where around the intake manifold, does a fuel pressure regulator ever give out? Well thanks for the help, I'm gonna go check it out again now that it's light out. Thanks in advance.
Here's the set up:
Build B16 bottom end
Stock head
Drag 3 kit
550cc RC injectors
AEM fpr & fuel rail
Old Nov 17, 2002 | 12:17 PM
TheIntegraGuy's Avatar
Default Re: Strange noise after boosting? (blu_si)
Check the O-rings on the injectors if you fiddled with them. They might have been torn.
Old Nov 17, 2002 | 01:57 PM
blu_si's Avatar
Default Re: Strange noise after boosting? (Esone3)
yeah, they are i need new ones. I'm hoping this is the problem
jdm.coupe3234
Jan 5, 2010 09:40 PM
mattsnooz
Jun 2, 2007 04:04 AM
RockLee`
Oct 10, 2006 09:01 AM
jdmcraze
Jun 30, 2004 05:05 PM
lsvtecivic
Feb 11, 2003 07:51 PM
