help shifting problems
my problem is when i shift sometimes it is hard to get in gear but if i play with the
clutch pedal at certain points it will shift smoothlybut if i press the clutch pedal all
the way down it won't go into gear. i replaced the slave cylinder and blead the
system but i didn't replace the clutch master because the pedal feells like it still
has pressureand i see no signs of leaks. but i dunno what else to do could it be the
clutch master needs to be replaced or is my trans the problem?
come on guys help me out any info will be greatly appreciated.
thanks,
thanks,
YangFlavor
Transmission & Drivetrain
Apr 14, 2009 07:24 PM
3.point.2
May 25, 2006 09:21 PM
