Quick? wich tranny bracket for EF b-series hydro tranny
Old May 31, 2007 | 10:23 PM
Boosteddb8's Avatar
Default Quick? wich tranny bracket for EF b-series hydro tranny
Do I use the rear tranny bracket from a DA or DC to put a hydro b-series tranny with the innovative convertion hydro mount kit
Old Jun 1, 2007 | 05:55 AM
IT GUY's Avatar
Default Re: Quick? wich tranny bracket for EF b-series hydro tranny (Boosteddb8)
use the rear "L" bracket that has a part number that begins with SK7..
Should be from a DA
Old Jun 1, 2007 | 06:05 AM
slow96coupe's Avatar
I thought you use the L bracket off the hydro??
Old Jun 1, 2007 | 06:10 AM
PDRIFT86's Avatar
Default Re: Quick? wich tranny bracket for EF b-series hydro tranny (IT GUY)
yeah, get the one from a DA integra, thats what i'm using for my b20 swap.
you need to drill out the bottom two holes for the bigger bolts that the hydro tranny
uses. i drilled mine on a drill press it was easy.
i also bought this http://www.innovativemounts.co...41000 to handle the cable/hydro problem and i must say, its a very
well engineered piece. pedal feel is just like the stock setup.
Old Jun 1, 2007 | 06:14 AM
so you cant use the l bracket off the hydro tranny??
Old Jun 1, 2007 | 06:19 AM
I CRX I's Avatar
thats a negative, the bracket is to big for the mount leaving to much free play
Old Jun 1, 2007 | 06:43 AM
side to side free play?? I was told that I just needed a spacer... Would that take up the slack or should i search junk yards for the da mount?
Old Jun 1, 2007 | 07:38 AM
IT GUY's Avatar
Default Re: (slow96coupe)
I bought my DA mount yesterday from Baranco Acura (sponsor on HT)
for like 44 bucks or something. Ask for Len or Chris if you order from them
http://www.barancoacuraparts.c...Irno=
Old Jun 1, 2007 | 06:50 PM
Boosteddb8's Avatar
Default Re: (IT GUY)
great thanks for the replys now I can finish up my friends swap
89CRXCRvtec
Apr 7, 2008 08:09 AM
Boosteddb8
Jun 7, 2007 07:03 AM
DC_RaceR
Feb 21, 2006 04:32 PM
Power Rev Racing
Jul 17, 2005 06:34 PM
fkncivic
Apr 11, 2005 06:34 AM
