Suspension & Brakes Theory, alignment, spring rates....
bump stops to short?
Old May 31, 2007 | 01:44 PM
Obama's Avatar
Default bump stops to short?
i just got some new illuminas and it didnt come with bump stops so im just going to re-use the ones off my agx's but they are pretty damn short like 3/4 of it is cut off does it matter how long it is?
Old May 31, 2007 | 04:24 PM
TEGNO1's Avatar
Default Re: bump stops to short? (rockthevote)
Depends how low you want to go relative the length of your shocks.
Install the shocks only without springs.
Jack up suspension to the ride height you want.
See how much travell you have.
If you want more at that ride height make them shorter.
If you want less make them longer.
Make sure you dont get carried away with suspension travell.
Go for around 20mm-40mm depending on ride height.
Kidnkorner
Suspension & Brakes
Mar 9, 2010 06:59 PM
dfoxengr
Suspension & Brakes
22
Sep 23, 2008 11:45 AM
chillax
11
Mar 29, 2004 08:44 AM
exquisite
Sep 26, 2003 08:55 PM
carblegal
Jan 30, 2002 01:47 PM
