Blower / A/C fan noise
Old May 31, 2007 | 12:07 PM
pipes's Avatar
Default Blower / A/C fan noise
98 Accord Lx
High pitch noise (squeeky) when fan is running. Fixable or need I replace whole unit? Anyone else with similar probs? Thanks.
Old May 31, 2007 | 02:27 PM
hondadude's Avatar
Default Re: Blower / A/C fan noise (pipes)
might just be something stuck in the fan blower cage, pretty easy to drop it out and look. but if you find no problem there, it isn't really worth the effort to take the motor all apart and lube the oil impregnated bushings.
Old May 31, 2007 | 03:14 PM
honda2002's Avatar
I had the same problem
Something was in the motor blower
You have to take the pasenger panel out
(see description on how to change the cabin filter)
and in the right corner there is a motor
You need to unscrew 3 screws (one way back)
and the motor will slide down
Ross
Old Jun 1, 2007 | 08:21 AM
pipes's Avatar
Default Re: Blower / A/C fan noise (honda2002)
cool so what was wrong with your motor? was there somthing stuck there, did you fix the problem?
mfrs
Mar 15, 2015 07:20 PM
super_coo
13
Dec 24, 2008 09:12 AM
Accordiac
Feb 9, 2008 02:10 PM
SLATER97EX
Aug 29, 2003 06:01 PM
