92 95 civic radiator help!
Old May 31, 2007 | 08:54 AM
fast22civic22's Avatar
Default 92 95 civic radiator help!
my radiator wont work for some reason i checked all fuses/relays.. added antifreeze
checked fuses relays with testlight/worked.. also connected a wire from the radiator plug to the battery and the radiator worked fine.... how can it be fixed w/o adding a on/off switch to radiator want it working w/o hitting the switch any ideas... thnx
Old May 31, 2007 | 09:05 AM
Default Re: 92 95 civic radiator help! (fast22civic22)
opinions r open!!
Old May 31, 2007 | 09:34 AM
chicows18's Avatar
So what your talking about is not the radiator but the radiator fan. If so, have you checked the fan switch? Does the motor on the fan work? Unplug the fan switch. Get a paper clip and jump the switch plug and see if the fan turns on. If it does, then the motor and fan are good still and the fan switch is not turning on. If it doesnt, then the fan motor needs to be replaced. The fan switch is fairly cheap so get one and replace and then run the car to warm up and see if the fan works. Worse case scenario, MR GASKET offers a temperature probe switch to turn on fans. Its a probe thats inserted into the radiator and once it gets hot it turn on the fan.
jacollins5
Honda Civic (2001 - 2005)
Sep 17, 2016 01:02 AM
asoRm
Aug 13, 2014 12:10 PM
dman81
May 28, 2014 03:20 AM
thisdamnhonda
21
Feb 26, 2012 09:47 AM
808MAUI
Feb 23, 2006 07:51 PM
