Suspension & Brakes Theory, alignment, spring rates....
Will these EF gc coilovers work on an EG?
Old May 31, 2007 | 06:28 AM
evosix's Avatar
Default Will these EF gc coilovers work on an EG?
http://www.importsnc.com/forum...23549
If I put an eg fork on these shocks will these bolt on to an eg?
Old May 31, 2007 | 09:06 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Will these EF gc coilovers work on an EG? (evosix)
I think you need the EF forks to make them work on an EG. The problem you will run into is that the EF shocks don't have enough stroke to work properly on an EG. This short stroke, and shorter front fork might not leave you enough droop to keep the front tires in contact with the road around corners. This will most likely result in excessive understeer. You could always give it a try though...
Old May 31, 2007 | 09:13 AM
Tyson's Avatar
Default Re: Will these EF gc coilovers work on an EG? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I think you need the EF forks to make them work on an EG. The problem....blahblah balh... You could always give it a try though...</TD></TR></TABLE>
forget all that. the only thing useful for you is the ground control sleeves and springs. you dont want to to be using them on a STOCK shock, especially a EF shock on your EG.
and its only a pair.
for $100, its not a bad deal really. youre only getting a pair tho. and you should put them on some good shocks like illuminas. wasting your time with putting them on stock shocks, ef or eg...
Joericci46
May 12, 2018 06:34 PM
rexracer626
Jun 11, 2010 11:31 AM
BanEL
Suspension & Brakes
Jul 25, 2008 01:13 PM
Lo-Buck EF
May 8, 2003 04:34 PM
