My First intake, First time welding alumnium
Old May 30, 2007 | 11:20 PM
crxsir23's Avatar
Default My First intake, First time welding alumnium
I made my first intake, not the best in the world but not too bad. The guy bailed on the velocity stacks. I didn't really have the tools to cut the alumnium so I made due with what I had. Not all that concistant with my welds. I was paying more attention to how the alumnium welded that anything (how the alumnium puddled and all those things). Do you guys sharpen your tungstens the same for alumnium as you do for other kind of metals? Because when I'm welding other metals I have pin point accuracy. Is there a way to get that with the alumnium welding?
Old May 31, 2007 | 07:03 AM
Andrew Marquis's Avatar
What are you going to do with the radiator hose?
Old May 31, 2007 | 09:40 AM
Bakeoff's Avatar
Ultra Lights? Pansy. lol
Why did you make it square instead of using a tube? Better plenum volume, but velocity might suffer. It looks like you did a pretty good job rounding out the runner transition.
Old May 31, 2007 | 11:42 AM
lkailburn's Avatar
very nice work for a first time! great job on the transition into the runners, it looks pretty good.
Old May 31, 2007 | 12:18 PM
standbackimapro's Avatar
What kinda car is that? A Neon?
How are you gonna run the radiator hose?
You should have cut off those square runners, welded on some allumnium tubing instaed of those stock ones
But it looks good for a first timer
Old May 31, 2007 | 12:19 PM
crxsir23's Avatar
Default Re: (lkailburn)
the radiator hose just dus lay on the intake. all the aluminum was a freebie that is y we did it like that i could have rounded it but really didn't wont to go through that much trouble this triangle is some thing like 4 feet to each corner
yes a 94 or 95 neon he needs to get a dame honda hahaha
[IMG][/IMG]
Old May 31, 2007 | 02:21 PM
Ohh, from the other angle it looked like tha manifold was sitting right on the radiator neck
Old May 31, 2007 | 04:56 PM
.RTErnie's Avatar
Default Re: (standbackimapro)
its not going to work...when the engine rocks back under acceleration it will pop the rad hose off or pinch it between the hood. I'd also be interested to see if the throttle cam will clear your starter.
Since you didn't weld that with it attached to the head...the head flange will be warped as expletive. trust me. you need to take that off and machine it.
is the battery being relocated? i don't forsee this clearing a stock battery tray or the iceman tray.
And you'll need to buy the 99 Neon throttle cable, because it wont reach the throttle body where you relocated the tb to.
Good luck!
Old Jun 1, 2007 | 08:51 PM
crxsir23's Avatar
Default Re: (.R T E r n i e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .R T E r n i e &raquo;</TD></TR><TR><TD CLASS="quote">its not going to work...when the engine rocks back under acceleration it will pop the rad hose off or pinch it between the hood. I'd also be interested to see if the throttle cam will clear your starter.
Good luck! </TD></TR></TABLE>
called soled motor Mont's flange not warped if i have the tools to make the intake think i can make every thing else work i would not assume to much not throw the pics we still have a lot of work but thank for the in put
Old Jun 1, 2007 | 09:33 PM
zexxbo's Avatar
Default Re: (crxsir23)
why are your beads so thick around the runners? looks pretty good tho other than that. also, i would pressure test the manifold before you run the car.
Old Jun 2, 2007 | 12:50 PM
crxsir23's Avatar
Default Re: (zeimbo)
i could not weld around the runers that good for some resion thay look bad i know littil more practes i guess im all so going to pressurer test it also
Old Jun 3, 2007 | 12:09 AM
503_EF9's Avatar
looks pretty damn good to me for a first time. always thought boxes looked weird and must be hell on good flow though.
BearsEK-KMSU
58
Feb 13, 2007 12:55 PM
mr_nemesis2003
Nov 30, 2006 11:41 AM
Justin Olson
Welding / Fabrication
Dec 6, 2005 03:29 PM
aarontrini85
26
Oct 24, 2005 01:21 PM
DLB1994
Nov 10, 2002 12:39 AM
