1993 cbr f2 will not start
my 93 cbr f2 will not start. bike have 34k miles. it have a brand new battery
today while riding it for about an hour i shut it off. then when i tryed to start it again about 5 mins after shutting it off it wouldnt start anymore. it turns/crank over very weak. theres a thing under the seats that makes a clicking/buzzing sound while trying to start it.all lights/cluster works.
i was readig how f2 have a problem about their regulator/rectifier going bad. can this be my problem?. can someone help me troble shoot this before i start spending money.
Check ALL your fuses and then after you check them
there's two things you may want to try...
1. Charge your battery and then give it a shot.
2. Try to bump start your bike. (aka bunny start, where you put the bike in 2nd gear, either have a friend push you or try and run while on your bike, and drop the clutch at around 10mph.)
If those dont work try replacing your battery and R/R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey »</TD></TR><TR><TD CLASS="quote">sounds like your R/R is dead and isn't charging your battery.</TD></TR></TABLE>
yep, the same thing happened to my bike when I bought it.
all fuses are good.
well today i charged the batter and bought a new reg/rec. bolted everything up and it started. rode the bike for about an hour. shut the engine off. waited about 5 mins then it started right away with no problems. then i rode the bike again for about 5 mins then it just died on me. then i kick started it. then about one or two blocks it died on me again. then i pushed it back home. it wouldnt start anymore even trying to kick start it. can it be my stator?
if you guys have any other tips/advise please let me know
thanks
thanks
people have already answered your question as to the problem. it's the regulator/rectifier. It's what recharges your battery when you have the motor on. It's a simple fix. It's not the battery, more then likely it isn't the stator, check the r/r. doing anything else is just wasting time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 »</TD></TR><TR><TD CLASS="quote">people have already answered your question as to the problem. it's the regulator/rectifier. It's what recharges your battery when you have the motor on. It's a simple fix. It's not the battery, more then likely it isn't the stator, check the r/r. doing anything else is just wasting time</TD></TR></TABLE>
uhhhh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSJ EG6 »</TD></TR><TR><TD CLASS="quote">bought a new reg/rec. bolted everything up and it started.</TD></TR></TABLE>
uhhhh
ShagginJet
Honda Motorcycles
Jun 2, 2004 05:05 PM
