No vtec and No cel's help......
Old May 30, 2007 | 10:07 PM
half jdm's Avatar
Default No vtec and No cel's help......
As the the title says i have no vtec and no cel. i have a crx with a pr3 obd0 ecu and b16a motor. I checked the wiring its all good, chnaged ecu's, changed the oil, and checked to see if the cel bulb worked. I figure it could not be my oil pressure or i would have gotton a vtp switch cel. any help would be great thanks.
Old May 30, 2007 | 10:10 PM
doublethink's Avatar
Default Re: No vtec and No cel's help...... (half jdm)
dented oil pan obstructing the pickup
that little screen thing on the actual solenoid might need cleaning
those are two possibilities that dont throw cels
Old May 30, 2007 | 10:42 PM
half jdm's Avatar
Default Re: No vtec and No cel's help...... (doublethink)
when i changed my oil i did notice a small dent in the oil pan it did no look like it was deep enough to affect the pick up but if my oil pressue was to low from the dent wouldn't i get a cel? thanks for the response
Old May 31, 2007 | 07:14 AM
EF_LSVtec's Avatar
take your vtec solenoid out and see if it's clogged...or test connection if it's actuating at vtec rpm...
Old May 31, 2007 | 09:15 AM
Boostedb20EH2's Avatar
Default Re: No vtec and No cel's help...... (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">take your vtec solenoid out and see if it's clogged...or test connection if it's actuating at vtec rpm...</TD></TR></TABLE>
My buddy had to clean his out.
Old May 31, 2007 | 09:24 AM
white90rexsi's Avatar
Doublethink. A dented oil pan whould cause low oil pressure and would cause a code for the v-tec oil pressure switch, and or your oil pressure light.
Old May 31, 2007 | 09:28 AM
Default Re: No vtec and No cel's help...... (white90rexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">Doublethink. A dented oil pan whould cause low oil pressure and would cause a code for the v-tec oil pressure switch, and or your oil pressure light.</TD></TR></TABLE>
Triplethink
He may be tuned on crome or someother engine management where most disable the vtec oil pressure sensor.
Old May 31, 2007 | 11:02 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: No vtec and No cel's help...... (Boostedb20EH2)
https://honda-tech.com/zerothread/1812135
Old May 31, 2007 | 03:57 PM
half jdm's Avatar
Default Re: No vtec and No cel's help...... (HondaPartsHero)
Thanks for the help i will try cleaning out my solinoid to see if that works and btw my ecu is chipped just to change vtec engagement to 5 grand and rev lim to 9000 i also tried using another virgin pr3 and still no vtec. no cel with either ecu so correct me if i am wrong but does this mean i dont have a oil pressure problem causing my no vtec but rather a problem with the solinoid?
raverx3m
Jan 28, 2013 07:34 AM
JaysonDC2
Apr 9, 2010 04:49 PM
high_octane
Jun 16, 2009 01:55 PM
da9driver
24
Aug 25, 2005 01:00 PM
ferio 95
Jan 14, 2005 02:19 PM
