Need help please Urgent!!!
I tryied hooking up my external coil and my cap today, everything was going great got it installed, and I went to cut my car off and the car would not shut off. I do have a turbo timer and all and it seems to work fine it counts down and all but when it goes to shut off all the accesories cut off but my car stays on. The only way I can cut my car off is to stall out. Also whenever my battery is hooked up even when the keys are not in the ignition, the car is at the secound postion, like when the key is in and you turn the key right before the car starts up, and this is when there are no keys. Somebody help me please.
Lee
Lee
This only started happening when you put the external cap and coil on? I don't know anything about that but what I do know about are ignition wires. Check your turbo timer wires to see if any are shorting out against the ignition or accessory wires. If you need wire colors call your local honda I am pretty sure by law they have to tell you wiring colors. Off the top of my head I know that Constant power is white...I can't remember ignition or accessory
Hope this helps....
Hope this helps....
Crimson_Tide
Apr 9, 2005 12:21 PM
Acura_I-RS
Jun 6, 2002 03:57 PM
