Suspension & Brakes Theory, alignment, spring rates....
ground control problem
Old May 30, 2007 | 06:38 PM
xaznxdrgnxboix's Avatar
Default ground control problem
i have a set of ground control coilovers for my 94 civic but when i unscrew the one screw and took it out it the coilovers wouldnt turn.. anyone know why
Old May 30, 2007 | 08:30 PM
gabebauman's Avatar
Default Re: ground control problem (xaznxdrgnxboix)
Probably some gravel or sand stuck in the threads. Try using one of them rubber strap wrench things or a screw driver and a hammer.
Old May 31, 2007 | 02:35 AM
Masterbobo's Avatar
Default Re: ground control problem (gabebauman)
yea, but first steel brush the tread all around, it can be a pain in the neck to adjust sometimes i know
Old May 31, 2007 | 02:34 PM
Default Re: ground control problem (Masterbobo)
il try tat thnx guyz
Old Jun 1, 2007 | 07:05 PM
stumpyf4's Avatar
Make sure you jack up the corner you want to adjust to take the load off the pearch.
Old Jun 1, 2007 | 09:17 PM
MaltBeer's Avatar
Default Re: ground control problem (stumpyf4)
I don't know if anyone else had this problem but I could never turn the collar by hand, I always needed a spanner wrench to do this.
Old Jun 3, 2007 | 06:18 PM
stumpyf4's Avatar
Default Re: ground control problem (MaltBeer)
Just installed mine and they turn easily with 1 hand. Just have to take the load off the pearch (i.e. jack up the corner you're adjusting). In the rear I have to take off the tire since I can't see the screw. But in the front adjusting with the tire on is easy.
Old Jun 7, 2007 | 02:14 AM
Masterbobo's Avatar
i still have my old skunk2 (junk 2) turning wrenches. those things are perfect for turning the locking nut on the GC thread, but im sure not many people have skunk2 keys laying around
Old Jun 7, 2007 | 10:25 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">In the rear I have to take off the tire since I can't see the screw. But in the front adjusting with the tire on is easy.</TD></TR></TABLE>
That's why I have my perches turned so that the set screws are facing the back of the car. This way...I can jack the car up from the rear tow hook, slide under the back and loosen the screw and turn with my hand. Makes it soo much easier to count revolutions to match sides for height on the collar too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Masterbobo &raquo;</TD></TR><TR><TD CLASS="quote">But I'm sure not many people have skunk2 keys laying around. </TD></TR></TABLE>
I still have mine.
Old Jun 7, 2007 | 02:28 PM
b16a1eg6's Avatar
WD-40 before you start turning them
Old Jun 8, 2007 | 10:13 AM
Masterbobo's Avatar
nice lol
lsvtek
Suspension & Brakes
23
Apr 18, 2008 08:16 AM
radzer0
Suspension & Brakes
Jul 24, 2005 07:02 PM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
djay86
Jul 31, 2002 08:06 AM
keys
Jul 21, 2001 08:31 AM
