CRX with ITR brake swap problem !!!
I swaped my stock crx front calipers with itr calipers and I can not seem to get a hard pedal. I've bled the brakes several times and there is no sign of air.
So my question is will I have to swap the master cylinder to the itr also.
Any help is appreciated Thanx.
you can use a 15/16 brake master cylinder and brake booster out of a 4-door civic EX or out of an acura integra and you will be just fine and they can be had for 50 bux or less from a junk yard.
Just the 90-91 4 DR EX civic MS and things will be good.
Make sure you got the 40/40 PV if you have the Rear Discs.
You cannot use the Integra one unless you mod one of the lines so don't bother.
Chance EG
Mar 16, 2018 10:39 AM
joprez
May 7, 2013 02:54 PM
hunan beef
May 9, 2011 03:43 PM
