Damn! thought it was the axle...
Old May 30, 2007 | 05:17 PM
ITRDC2R's Avatar
Default Damn! thought it was the axle...
Went to my friend who is a mechanic today, because I had alot of knocking noises when I turn the steering wheel to the left sharply.
Now its even when im driving straight, humming like NUTS...
So anyways, the boot was ripped, and you can see the inside and it wasnt that greased , so thought it was the axle.. im sure it had to be changed anyways
I take it out, and its stil there.. damn.. we put up the car, the wheel is TIGHT .. no play or movement at all, 9 - 12 position, etc. The front wheel was cupped, so we rotate the wheel, and put the rear one up front, I take it out.. Stil there..
So yeah, we thought it cant be the wheel bearing at all, since its so tight and no play.. but there is alot of humming when we spin it.. so its GOTTA be it..
Gotta go back monday and fix the bearing this blows, driving it right now like this is scary
Old May 31, 2007 | 09:18 AM
itr1244's Avatar
Default Re: Damn! thought it was the axle... (ITRDC2R)
yeeeh. wheel bearing it is .. i guess.
mine didn't have any play when i try to move it 12-6 o'clock.
but yeah. my wheel bearing was shot
Old May 31, 2007 | 09:27 AM
GO-FIGHT-KILL's Avatar
Just to let you know, I had the EXACT same problem... A VERY loud and annoying humming sound (I created a thread about it a while ago, I'll dig it up for ya') coming from the passenger side wheel.
I thought it was the wheel bearing, but I changed the brake pads just to be sure... It sounds stupid, but this fixed the problem, and it hasn't come back. I don't know how it was causing the humming, but it was.
Try that first.
Old May 31, 2007 | 09:29 AM
It's a long read, but it sorts itself out at the end, along with cats.
Old May 31, 2007 | 10:11 AM
MatrixShark's Avatar
Default Re: Damn! thought it was the axle... (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">yeeeh. wheel bearing it is .. </TD></TR></TABLE>
I second this. I had a wheel bearing go bad (R/FR). You know, the typical humming noise that changes pitch with speed and comes and goes as you sway the load. I replaced it and everything was great for a while. After about six - seven months a grinding noise started. The noise was REAL bad when I turned the car sharp left at low speeds. Long story short, it turned out to be a defective wheel bearing (same one that I had just replaced). Swapped in another new one and now she's smooth as silk again. (Thank god for tech friends that are easily motivated with generous gifts of alcohol )
Old May 31, 2007 | 12:41 PM
citrus3000psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRDC2R &raquo;</TD></TR><TR><TD CLASS="quote">Went to my friend who is a mechanic today, because I had alot of knocking noises when I turn the steering wheel to the left sharply.
Gotta go back monday and fix the bearing this blows, driving it right now like this is scary </TD></TR></TABLE>
What side is it on? If its the drivers it could be the intermediate shaft bearing.
Old May 31, 2007 | 12:47 PM
Haleiwa-Brando's Avatar
Default Re: Damn! thought it was the axle... (citrus3000psi)
Just for fun, I would also check the inner tire walls of whatever side the noise is coming from.
Old May 31, 2007 | 02:24 PM
R.Kelley's Avatar
the best way ive found to find bad wheels bearings is to put your hand on the sping and spin the wheel....just feel for a roughness
Old May 31, 2007 | 07:18 PM
ITRDC2R's Avatar
Citrus, its gonna be the passenger front..
When i flcik it to the left (steering wheel) it gets LOUD..thumping, clicking.. then i slowly progress to the RIGHT it goes away for a second, then it comes back and sounds like **** even driving straight.. if i make right turns, it goes away and just hums.
GO FIGHT KILL: Yeah, you got way different symptons ;P glad to hear you got it fixed
Yes, it is good to have mechanic friends Acura wants $300 for a ******* bearing, i asked the service guy if they are crazy. He said "No..." YEEEEAA
Old Jun 1, 2007 | 05:43 AM
Default Re: (ITRDC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRDC2R &raquo;</TD></TR><TR><TD CLASS="quote">Acura wants $300 for a ******* bearing, i asked the service guy if they are crazy. He said "No..." YEEEEAA
My (from the dealer) wheel bearing was no way near that much! Maybe they were quoting you the rear with the hub too.
.BigSexy
39
Sep 10, 2013 02:57 AM
method520
Mar 15, 2010 09:08 AM
HOODLOVER
Oct 26, 2008 07:24 AM
ryanstev
Suspension & Brakes
Nov 13, 2007 05:24 AM
truevietluv636
Sep 8, 2007 03:00 PM
