Another Important FYI: 94-97 vs 98+ Power Steering Pumps/Inlet Hose
Old Jun 3, 2002 | 11:46 AM
IN VTEC's Avatar
Default Another Important FYI: 94-97 vs 98+ Power Steering Pumps/Inlet Hose
I came to find out yesterday that the two are not compatible. I bought a '99 GS-R PS Pump from B18curmama and slapped an AEM pulley on it. I did it b/c somewhere in the PS system, it was blowing a leak. Mine's is a '95 GS-R, and I ran into a totally frustrating problem with it.
The rack feeding hose (hose that routes next to the cam gears) has a different fitting into the power steering pump, as does the fitting on the pump. The fitting is larger on the 98+'s, and the bolt pattern is also different. I'm pretty sure the 10mm bolts are the same tho.
Even Duluth Acura Carland lists a (1) and (2) for different PS Pump parts.
< http://www.acuraautomotiveparts.net >
As of now, I'm running with no power steering and absolutely loving it. My only solution is to buy a need feed hose and replace. $102.99...yick.
Old Jun 3, 2002 | 01:23 PM
IN VTEC's Avatar
Default Re: Another Important FYI: 94-97 vs 98+ Power Steering Pumps/Inlet Hose (IN VTEC)
After reading my own post, I realize that I must've traumatized my medulla oblongata b/c I sounded like a retard.
Anyways, the whole point of the post was that the older and newer pumps are different and require both the pump and a compatible hose for it to work.
arziffel
Jun 8, 2012 09:34 AM
SoTexDC2
Jul 16, 2009 01:39 PM
import-tooner
Apr 30, 2009 04:09 PM
illaborate978
May 8, 2007 04:47 PM
Drkaccrd
May 26, 2003 01:28 PM
