d16y8 head gasket on d16a6
Old May 30, 2007 | 06:37 AM
austincrx's Avatar
Default d16y8 head gasket on d16a6
has anyone ever put a d16y8 head gasket on a d16a6 block and head?
i think it will work, that is if the blocks are the same, which i think they are, just different heads. the reason is that the y8 head gasket is half as thick as the a6 head gasket, and the compression will go up. i've heard of one other person doing this on http://www.crxcommunity.com but i don't want to destroy any valves or anything.
thanks
Old May 30, 2007 | 06:47 AM
rice a roni's Avatar
Default Re: d16y8 head gasket on d16a6 (austincrx)
yep works. they are all interchangeble...dont use the a6 headgasket or you'll have to scrap it off...
Old May 30, 2007 | 08:48 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
^^yep...
all i would add is that a few of the coolant passage holes dont match exactly with the a6 HG....you can leave it, or dremel them out as i did....
this is just from memory...i last did this back in 2002
Modified by fastcrxsi90 at 3:13 PM 5/30/2007
Old May 30, 2007 | 09:30 AM
slow96coupe's Avatar
y8 and z6 blocks are the same...
I did a minime with a a6 block and used a z6/y8 hg... didnt do anything about the coolent holes and never had a problem.
Old May 30, 2007 | 12:10 PM
stnguyen82's Avatar
Default Re: (slow96coupe)
should work fine
Old May 30, 2007 | 02:58 PM
EF9 JAMS!!!'s Avatar
Default Re: (stnguyen82)
i'm usingi the 98 ex head gasket it's the best one to use
Old Jun 2, 2007 | 02:00 PM
austincrx's Avatar
alright, thanks guys!! i've got one coming in on monday.
lilsicsoul
Mar 11, 2009 04:21 PM
sinfulj32
Nov 29, 2005 06:54 AM
JDMCRX
May 1, 2005 07:54 PM
gabspeed
20
Mar 14, 2005 11:43 AM
lonefuzzy79
Dec 7, 2002 08:33 PM
