SHOOT ME NOW.....OIL LEAK FROM BACK OF HEAD ON FRESH LS/VTEC SWAP
SO i took the cams out and checked to see if need to be torqued down it needed a full turn on cyl#3+4 so i put it back to gether and same **** MASIVE oil leak..... the motor idles mint but pisses oil(arround .33 quart every 15-20min) so tomorrow im taking the head off to so if i put the gasket on wrong but im almost pos that you can read the numbers on the gasket befor i bolted it up
im abt 69% sure its on correctly.
also i think it might be the golden lsvtec dowels cuz i had the head cleaned and checked and the block was honed and checked to see if it needed to be decked and the michinest said it was mint.... any info will be mint ill let you know if i figure out the problem tomorrow
im abt 69% sure its on correctly.also i think it might be the golden lsvtec dowels cuz i had the head cleaned and checked and the block was honed and checked to see if it needed to be decked and the michinest said it was mint.... any info will be mint ill let you know if i figure out the problem tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slaminsam »</TD></TR><TR><TD CLASS="quote">did you use an ls head gasket and did you remember to plug off the oil hole in the head for vtec?</TD></TR></TABLE>
yup
yup
b16civster
22
May 31, 2007 06:01 PM
