need help with bolts
Ok I just tried to call hasport to see what part numbers the bolts on back of the rear tranny bracket for the 90-93 integra for the b20 swap/b16 tranny are but no luck cause they are closed...wondering anyone on here could help me out on this one thanks...
they arent open at 5am :-( and co-worker dont let me bring phone to work anymore cause everyone calls me...but hasport site says the bolts are like 14x1.25 and the dealer says 12x1.25 so I am confused :-(....please help!
ok well my gsr tranny took 2 14 1.5 bolts and i had to dril the holes on my 90-93 bracket to make it bigger so i believe the size should be 12 not 14 and the thread count seems to be consistant so stick with 1.25
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I »</TD></TR><TR><TD CLASS="quote">ok well my gsr tranny took 2 14 1.5 bolts and i had to dril the holes on my 90-93 bracket to make it bigger so i believe the size should be 12 not 14 and the thread count seems to be consistant so stick with 1.25</TD></TR></TABLE>dont understand....from what hasport says to drill out rear lower t bracket which was done already by last owner...he had 2 standard bolts in there and I want the grade 8......
well i figured my tranny took larger bolts then the b16 tranny being its a 94 hydro tranny but now im not to sure being as the last owner drilled out the bracket also:-\ just go to majestic honda and check the size for a 99-01 civic si, i believe they should be the same. one thing i can be sure of is that its either 1.5 or 1.25 for the thread cound thats the most common bolt thread used for hondas. ps the majestic honda link is in the FAQ thread.
EDIT: i think it should be part number 18 in this link http://www.hondaautomotivepart...84%29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I »</TD></TR><TR><TD CLASS="quote">well i figured my tranny took larger bolts then the b16 tranny being its a 94 hydro tranny but now im not to sure being as the last owner drilled out the bracket also:-\ just go to majestic honda and check the size for a 99-01 civic si, i believe they should be the same. one thing i can be sure of is that its either 1.5 or 1.25 for the thread cound thats the most common bolt thread used for hondas. ps the majestic honda link is in the FAQ thread.
</TD></TR></TABLE>thanks mate ya I have to use an t bracket drilled out to fit size 14 bolts for hydro tranny....just wasnt sure what bolts to get but I order those tomorrow....
1984eghatch
Sep 17, 2011 08:09 PM
averyvm
Aug 7, 2007 09:57 PM
PhatHardy
Feb 24, 2003 10:07 PM
