is there a diy for front lower control arm bushing replacement?
as the topic states i need to replace both front sides where shock forks bolt up.i already have the new bushing i was just wondering if there was a write or a diy.please help a fellow ef'er out.
they come off easy just unbolt the whole arm and to get out the old bushings i burned out the rubber. then it leaves a metal sleave. i cut that with a sawzall then chizzle the bitch out
actualy tried that with one but it tore out the rubber
if you have the right stuff a press would work easy
ok i that is what i was going to do tommorrow at work,but i just wanted to make sure it was the right way to do it.thank so very much people for you helpful input
SpecialRequest
Jan 20, 2016 02:02 PM
thisboyjulio
Oct 23, 2006 08:34 PM
