locked my keys in my car
Old May 29, 2007 | 01:55 PM
liquidx's Avatar
Default locked my keys in my car
well it was raining i had my nike dunks on so i changed my shoes in the process i locked my keys into my trunk......
anyway i can get it open? i tried a hanger tried to open the trunk and front door i guess i was "picking" the lock......so no go?......i parked in a tow away zone......need help ASAP
Old May 29, 2007 | 01:58 PM
Championship's Avatar
Default Re: locked my keys in my car (liquidx)
you can open it with a slim jim, i made one out of a thick coat hanger and go crazy inside the driver side passenger weather strip
Old May 29, 2007 | 02:01 PM
liquidx's Avatar
on the outside of the driver side passenger weather strip or do i actually have to try to bend the windows and stick the hanger inside?
Old May 29, 2007 | 02:04 PM
Default Re: (liquidx)
make the wire into a hook and go in between the window and the weather stip (above the door handle) and just hope you have luck to unlock the door
just try to grab something in there, go half way of the door and then just pull up. i did this 2 times and i succeded.
goodluck
Old May 29, 2007 | 02:06 PM
fishhead's Avatar
yes have a friend hold/pull back the door frame/weather stripping so you can get a hanger down in there to lift up the unlock switch. that is the second best way besides a brick.
Old May 29, 2007 | 02:15 PM
wong_520's Avatar
if ur able u can get a key cut with ur vin# unless the locks were changed in the history of the vehicle. the dealerships can cut u a key.
Old May 29, 2007 | 02:20 PM
Default Re: (wong_520)
sucks cuz its gonna get towed
Old May 29, 2007 | 02:26 PM
tegda's Avatar
Default Re: (Championship)
i did that the other day at school ..cost me 50 bucks to get them out
Old May 29, 2007 | 03:01 PM
98GSRrdr's Avatar
Default Re: (tegda)
Get a wedge... and get the door open alittle... then like everyone else said .. coat hanger.. ive done it many times on different kinds of cars.. just go for the door lock .. pull it up.. very e/z for a teg
Old May 29, 2007 | 03:09 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (98GSRrdr)
Have you tried using a tennis ball?
http://youtube.com/watch?v=68ttwlQ1P2M
Old May 29, 2007 | 03:21 PM
Integra4lyfe069's Avatar
Default Re: (CARMA_626)
dont ruin yer cars door or frame... just use a table knife put it in where the door window top meets the car frame..... pry it open enough to get a hanger inside the rubber on the window, then use the hanger to pull up on the trunk release button and there you go, your in yer trunk and can climb in threw theback of thecar to unlock yer doors, this method takes 5 minutes or less, im a pro at it now i always lock my keys in haha.. GG trunk release button.
driver side only for ppl who dunno what that little silver button on their panel is for haha
Old May 29, 2007 | 03:27 PM
whattodo's Avatar
Default Re: (Integra4lyfe069)
How can i take off the bolt on the top of my strut, where you insert the alan wrench if it is rusted out?!
Old May 29, 2007 | 03:32 PM
Chewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra4lyfe069 &raquo;</TD></TR><TR><TD CLASS="quote">dont ruin yer cars door or frame... just use a table knife put it in where the door window top meets the car frame..... pry it open enough to get a hanger inside the rubber on the window, then use the hanger to pull up on the trunk release button and there you go, your in yer trunk and can climb in threw theback of thecar to unlock yer doors, this method takes 5 minutes or less, im a pro at it now i always lock my keys in haha.. GG trunk release button.
driver side only for ppl who dunno what that little silver button on their panel is for haha</TD></TR></TABLE>
trunk release button? from 97 on, there is no trunk release lever. Were you referring to the silver toggle that electronically unlocks the doors and trunk? Tegs are notoriously with trunk lock problem. So you might be one of the lucky ones that has a working trunk lock.
Old May 30, 2007 | 11:47 AM
liquidx's Avatar
well.............after trying with the hanger and pulling up and down.......i went to ace to ask for a slim jim and found out there was a locksmith next door.......they opened my door for free cuz i was in the parking lot.......and with the hanger i fucked up my window cuz it won't go down anymore.......so imma have to pop it off or something and see what damage i did........thanks alot for the replies
Old May 30, 2007 | 12:00 PM
JDM_CRX_PLEASE's Avatar
u shoulda just peeld the window, stuck ur arm inside and unlock it urself. ive done it to my car, and my brothers car more than once.
hes a noobie driver and keeps forgetting his keys inside.
i have friends who are ex theivs. they dont stel anymore, they served there time in jail for it.
Old May 30, 2007 | 02:30 PM
slammedNslowLS's Avatar
take a 1inch wide puddy knife. slide it under the weatherstripping between the window and the weatherstripping and pry the window back. makes it so easy and you never expletive your car up
Old May 30, 2007 | 03:28 PM
Dilly's Avatar
Default Re: (JDM_CRX_PLEASE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE &raquo;</TD></TR><TR><TD CLASS="quote">i have friends who are ex theivs.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedNslowLS &raquo;</TD></TR><TR><TD CLASS="quote">take a 1inch wide puddy knife. slide it under the weatherstripping between the window and the weatherstripping and pry the window back. makes it so easy and you never expletive your car up</TD></TR></TABLE>
he already got it. haha.
Old May 30, 2007 | 04:18 PM
teg your it's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried using a tennis ball?
http://youtube.com/watch?v=68ttwlQ1P2M </TD></TR></TABLE>
i saw that long time ago. does it even work?
Old May 30, 2007 | 04:29 PM
Blahblah718293's Avatar
Default Re: (CHOcobo)
got tripple A? id just get the hanger in there and pull the power lock swtich up.
thx for making a thread on how to break into tegs.
Old Jun 9, 2007 | 07:51 AM
Default re:
chewie tegs do come with the silver trunk release button from 97 and on, i had one in my 2000 se and 99 ls
wdutton
Dec 1, 2011 06:52 PM
solesthatgo
Apr 5, 2010 10:12 PM
CR91X
Dec 9, 2009 01:37 PM
Diao
Jan 10, 2007 04:29 PM
dskny
Feb 25, 2003 07:50 PM
