ReD LiNe aT 4,000 RPM.....???
for some reason now since my check engine light is on.....sometimes my car just randomly redlines at 4,000 rpm in every gear...no matter how much i gas to try to go above 4,000, rpm it will not hit my regular redline if the check engine light is on.....any help guys on what can be the problem.....this car is stressing me out like crazy....
scan the code. Its going to be a somewhat major code. Likely a position sensor (either the cam, crank or throttle), ignition issue, or something like that.... the ECU cant figure out whats going on and is trying to save the motor.
just pull the negative cable on the battery for about 15 minutes to reset the ECU. that should take care of the problem. if it still persists after you try resetting the ECU, than get it scanned.
Y2A
Nov 4, 2003 07:57 PM
RicedREX
Jun 24, 2003 10:22 PM
