fuel pump issue
Old May 29, 2007 | 12:17 PM
wernhersey's Avatar
Default fuel pump issue
My buddys EF is haveing a fuel problem. The pump only turns on every so many turns of the key. If you turn it over when the fuel pump turns it fires right up and runs fine. But sometimes the pump will not give a prime pulse when you first turn the key. I am womdering if anyone has herd of this and if so what caused it. My thoughts are the ignition switch.
Old May 29, 2007 | 12:35 PM
Andy R's Avatar
Default Re: fuel pump issue (wernhersey)
Yeah i'd say ignition switch or main relay.
Old May 30, 2007 | 11:54 AM
wernhersey's Avatar
I Think im gonna check the main relay contacts and make sure there clean. Thanks for the help.
Old May 30, 2007 | 03:58 PM
gp70hs's Avatar
Very likely it's the main relay. I don't think their is any way to clean the main relay contacts, the way the relay is built. I pulled one apart and rebuilt it, but I wouldn't trust it and I had some tools to use that aren't generally available. They are a bit pricey, but you'd probably be better off to have him purchase a replacement, before you do much of anything else. Odds are probably 10:1 in favor of the relay, over the ignition switch IMO.
acidburn2k2
Dec 10, 2009 06:25 AM
EfSedanLove
Dec 29, 2008 07:38 PM
Discontained
Sep 8, 2006 10:13 AM
JaHnAbOi
Oct 4, 2004 10:39 PM
RenoRacing
Sep 8, 2002 09:41 PM
