rear disk upgrade, now soft pedal...what do i need to fix?
Old May 29, 2007 | 11:24 AM
rps_ak's Avatar
Default rear disk upgrade, now soft pedal...what do i need to fix?
i switched the rear drums to disks on my 95 hatch from a 94 integra...
the pedal has become much softer than before and requires quite a bit
of force to get the brakes goin....
what do i need to improve this feel? booster and m/c? or maybe just
a proportioning valve...need some suggestions
Old May 29, 2007 | 11:27 AM
instructor74's Avatar
Default Re: rear disk upgrade, now soft pedal...what do i need to fix? (rps_ak)
rebleed the system it sounds like you still have air in it. Start at the rr,lf,lr,rf bleed each one with a hose into a clear container with brake fluid in the bottom until all bubbles are gone and fluid is clear. Make sure and keep the M/C topped off with fluid
Old May 29, 2007 | 11:58 AM
delslo93's Avatar
Default Re: rear disk upgrade, now soft pedal...what do i need to fix? (instructor74)
You will probably want to get a 15/16" master cylinder and a 4040 prop valve.
Old May 29, 2007 | 12:01 PM
Fitti's Avatar
Default Re: rear disk upgrade, now soft pedal...what do i need to fix? (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">You will probably want to get a 15/16" master cylinder and a 4040 prop valve. </TD></TR></TABLE>
I'm not sure if those will help pedal feel but will more than likely make the brakes work better.
As mentioned above bleed the brakes lines. I did a similar swap on my car and after bleeding them the brakes work like a champ. Read the manual on the proper way to bleed the brakes.
Old May 29, 2007 | 12:07 PM
delslo93's Avatar
Default Re: rear disk upgrade, now soft pedal...what do i need to fix? (Fitti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti &raquo;</TD></TR><TR><TD CLASS="quote">
As mentioned above bleed the brakes lines. I did a similar swap on my car and after bleeding them the brakes work like a champ. Read the manual on the proper way to bleed the brakes.</TD></TR></TABLE>
Yeah bleeding them will def. help. I think you only need the stuff I listed if you do the bigger front calipers also. With just the rears you should be fine with your stock stuff but if it doesn't improve with just a bleeding of the lines try replacing the MC and the prop valve.
Old May 29, 2007 | 12:44 PM
vrrodri's Avatar
did you bleed the brakes?
Old May 29, 2007 | 04:40 PM
92VXeg's Avatar
15/16 master cylinder=1991 Civic EX Sedan=Stiffer Pedal Feel
Old May 29, 2007 | 04:44 PM
1clean_ Ej's Avatar
Yea what he said..........and bleed'em
Old May 29, 2007 | 05:37 PM
BRNRone's Avatar
Pump the brakes with the key off. If the pedal still feels mushy and doesn't get hard as hell, you need to bleed the brakes.
GoLowDrew
Suspension & Brakes
Sep 15, 2015 08:36 PM
douglaslovin
Nov 26, 2009 11:41 AM
slicermage
Aug 4, 2006 07:16 PM
WSG_buBble
Apr 2, 2004 09:40 AM
