new swap no spark and no oil light????????? i checked everything!!!!!!!!!
Old May 29, 2007 | 11:20 AM
b16civster's Avatar
Default new swap no spark and no oil light????????? i checked everything!!!!!!!!!
the car rand mint with its orignal motor tow with the new b swap there is no spark and also after first cranking over the oil light was on and i cranked it at it shut off and has not come on yet....
i checked every fuse every ground and added more
the blk/yel wire at coil has +12v and i tried 2 different dizzys
has anyone seen this befor???
pics of the bay
Old May 29, 2007 | 12:14 PM
89efDUSTY's Avatar
Default Re: new swap no spark and no oil light????????? i checked everything!!!!!!!!! (b16civster)
i know this sounds dumb, but are you sure of the firing order>? also is your oil pressure sensor connected &/or faulty?
Old May 29, 2007 | 02:28 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: new swap no spark and no oil light????????? i checked everything!!!!!!!!! (89efDUSTY)
your injector resistor box looks unplugged to me..
Old May 29, 2007 | 04:47 PM
b16civster's Avatar
Default Re: new swap no spark and no oil light????????? i checked everything!!!!!!!!! (sanimalp)
i fixed the situation it was a cut wire from the ecu
just to let you guys know the resistor box nor the firing order have to do with getting spark....
Old May 29, 2007 | 04:59 PM
sanimalp's Avatar
$cat /dev/urandom
having no fuel wont start your car, so that you know.
Old May 29, 2007 | 05:54 PM
b16civster's Avatar
it had fuel
Old May 29, 2007 | 11:19 PM
sanimalp's Avatar
$cat /dev/urandom
what wire was cut?
Old May 30, 2007 | 10:20 AM
b16civster's Avatar
the white signal wire from the ecu
JaysonDC2
Mar 24, 2010 03:04 PM
92integraVTECgsr
Jun 7, 2008 02:35 PM
Eibach95Civic
Apr 17, 2007 01:52 PM
1997_prelude
Aug 2, 2006 08:35 PM
sporkcrx
10
Jul 27, 2003 11:54 AM
