Need help with a 240sx engine. Tried posting other places but the other forums ppl aren't as helpfu
Old Jun 3, 2002 | 09:04 AM
The Rob's Avatar
Default Need help with a 240sx engine. Tried posting other places but the other forums ppl aren't as helpfu
Here's what my friend says happens: (I just copied and pasted what he sent me)
when the car gets hot the thermostat opens water begins to circulate though the block ... now when this happens it begins to leak water somewhere causeing the water to come back out the intake manifold and then get dumped into cylinders
causing it to run not only real hot but stall and foul the plugs
What could be the cause of this. Compression is also steady between all the cylinders.
Old Jun 3, 2002 | 09:06 AM
X2BOARD's Avatar
Default Re: Need help with a 240sx engine. Tried posting other places but the other forums ppl aren't as he
Try a crosspost in members' corner... lots of peeps are there...
Old Jun 3, 2002 | 09:21 AM
garados's Avatar
could be a head gasket.
Old Jun 3, 2002 | 09:39 AM
Tweakmeister's Avatar
I'm guessing some kind of gasket. I'm not sure what gaskets go where on that engine so inspect gaskets and look for cracks in not only the gaskets, but also the block, etc.
Old Jun 3, 2002 | 12:18 PM
ndustryalGSR's Avatar
Aside from a head gasket, the intake manifold gasket and throttle body gaskets might be worth a look, too, based on what your friend mentioned about the coolant coming out of the intake manifold.
Good luck. I assume you're working on a KA engine, not the SR?
Old Jun 3, 2002 | 12:24 PM
Mr. Softee's Avatar
try altimas.net the altima uses the same engine.
Old Jun 3, 2002 | 03:59 PM
asianautica's Avatar
try here:
http://forums.freshalloy.com/cgi-bin/ultimatebb.cgi
Old Jun 3, 2002 | 04:02 PM
95SiR's Avatar
probably a blown/leaking head gasket
Old Jun 3, 2002 | 04:05 PM
mattL's Avatar
if that was the case you'd have hydrolock and a lot more wrong than burnt plugs.
Old Jun 3, 2002 | 04:30 PM
samagon's Avatar
what are the symptoms?
does it blow white smoke?
the thermostat opening shouldn't have anything to do with it.
the intake afaik, isn't attached to the cooling system at all.
there is always water in the block.
the order in which water passes through the cooling system, starting at the radiator.
lower radiator hose ---> water pump ---> cooling passages in the block ---> cooling passages in the head ---> thermostat ---> upper radiator hose ---> back to radiator.
did your friend physically look into the intake and see coolant?
chances are very high that your friend has a blown head gasket, or something eaqually as bad, possibly worse.
civicguy167
Dec 12, 2012 09:11 PM
single_slam
Mar 5, 2012 10:20 AM
elmejor
Jul 17, 2009 03:45 PM
chu77
Jul 25, 2006 05:03 AM
Jeffrey9
Nov 27, 2005 12:25 PM
