Koyo Racing Radiator Woes...
Old May 29, 2007 | 09:25 AM
solorex's Avatar
Default Koyo Racing Radiator Woes...
Recently picked up a Koyo Aluminum radiatior. So much for "direct fit", it doesn't even come close to fitting between the front crossmember and the rad support. Only 3 out of the 4 mounting tabs for the stock fan line up and it looks like the stock fan cannot be used anyways since it will hit the crossmember.
Anyone else have these issues? It's a nice rad, but I am questioning whether it's worth it for all the surgery I'm going to have to do. Do Fluidyne's fit better?
Old May 29, 2007 | 09:30 AM
jdmd15bciviconrice's Avatar
Default Re: Koyo Racing Radiator Woes... (solorex)
Fluidyne's is a much better fit, mine bolted right up no problems, I also have a half in it so.....but it cools a hell of alot better than oem.
Old May 30, 2007 | 07:51 AM
solorex's Avatar
Default Re: Koyo Racing Radiator Woes... (jdmd15bciviconrice)
Thanks for the input. I bit the bullet and ground off all the mounting tabs (for A/C) etc. so that the rad will clear the crossmember, next up is bending the lower rad support to clear and I'm going to have to buy a flexilite fan.
Seems like a lot of messing around but the Koyo does seem to be a better rad overall than the Fluidyne. It's thicker and the upper and lower dowels are nicer...
I will try and post some pics when I am done.
Old Jun 9, 2007 | 07:48 PM
blazed_racer's Avatar
any pictures of what you needed to mod?
any pics of the new fan ?
Old Jun 10, 2007 | 12:32 AM
kwichang's Avatar
Default Re: (blazed_racer)
Not sure what type of EF you've got...here's how I had to modify a Koyo to fit in my 91 CRX SI. Basically just hacksawed off the areas indicated.
Final fitment - stock fan works OK too (never comes on now though heh-heh)
Old Jun 10, 2007 | 01:25 AM
I got a ef9.
damm, that radiator is huge?
ever consider running no fan?
my stock Radi never gets over 1/4 mark on stock gauge.... in city traffic, my alloy one is not as big as your one, but if I had that rad, my temp wont move
Old Jun 10, 2007 | 01:33 AM
kwichang's Avatar
It was advertised as a "drop-in" fit - thought it would be a snap
Actually, the fan did come on once...when I seafoamed my engine before taking a smog test. Even with fan not running coolant temp never moves above 1/4 mark even on the hottest days.
Old Jun 10, 2007 | 06:31 AM
Mr.Death's Avatar
Default Re: (kwichang)
I have a fluidyne 1/2 rad which was supposed to be a direct fit but was far from it. I had to upgrade to a traction bar and hammer the underside of the hood to make it fit and it's still a tight fit.
Old Jun 10, 2007 | 07:48 AM
kwichang's Avatar
Default Re: (Mr.Death)
I had to hammer the underside of the hood slightly to get it to close also
Old Jun 10, 2007 | 02:16 PM
any picture of the underside of the hood?
Old Jun 10, 2007 | 05:57 PM
Iron_Forrix's Avatar
i got an aftermarket full size radiator.
its a ready rad radiator i got for 150
fits like a glove, no hacking, bolts right up, cools AWESOME!
Old Jun 10, 2007 | 06:53 PM
Bob_760's Avatar
Default Re: (Iron_Forrix)
yay radiator thread lol (just got mine)
Here's my Fluidyne with 2 12" slimline fans.
Old Jun 10, 2007 | 08:30 PM
Mr.Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazed_racer &raquo;</TD></TR><TR><TD CLASS="quote">any picture of the underside of the hood?</TD></TR></TABLE>
Old Jun 10, 2007 | 08:35 PM
kim_2_da_chee's Avatar
lol cool dog
Old Jun 10, 2007 | 08:43 PM
kwichang's Avatar
Just a little pounding - not too bad really...
Old Jun 10, 2007 | 10:51 PM
if your EF a prefacelift or facelift?
Old Jun 10, 2007 | 11:05 PM
kwichang's Avatar
facelift / prefacelift ?? what do you mean?...body/hood is all stock USDM
Old Jun 10, 2007 | 11:15 PM
is USDM totally different to JDM ?
facelift or prefacelift? do USDM EF not come out with faceift?
Old Jun 10, 2007 | 11:32 PM
h22 kamikazi's Avatar
how much did you pay for your fluidyne bob?
Old Jun 10, 2007 | 11:41 PM
kwichang's Avatar
Sorry - never heard of "facelift" before. Just noticed you're in NZ... I'll defer on exact US-JDM differences in hood/latch area to someone who knows (I'm not sure)
Old Jun 10, 2007 | 11:51 PM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazed_racer &raquo;</TD></TR><TR><TD CLASS="quote">is USDM totally different to JDM ?
Sorry, in the US the term facelift isn't as commonly used for the body differences. I'm assuming you're refering to 88-89 (pre-facelift) and 90-91 (facelift)? Or do you mean the SiR front end (we didn't get that allthough alot of people import them).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 kamikazi &raquo;</TD></TR><TR><TD CLASS="quote">how much did you pay for your fluidyne bob?
$340, it's the Fluidyne 90-93 DA Integra radiator so it has the B-Series sized fittings.
Old Jun 10, 2007 | 11:54 PM
STREETWERKZ's Avatar
i dont recall the koyo being too much of a pain to install in my car. maybe hacksawing off a few areas on the bottom. but thats it. it even fit under the hood without touching, i was able to use the factory fan, and used the factory mounts and whatnot. im even going to use it on my newer setup. just switch to a thin pusher fan this time though.
Old Jun 11, 2007 | 12:04 AM
Default Re: (Bob_760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">
$340, it's the Fluidyne 90-93 DA Integra radiator so it has the B-Series sized fittings. </TD></TR></TABLE>
yeah thats it.. referring to 88-89 and 90-91... sorry, did not realise you guys didn't use facelift and prefacelift.
Old Jul 24, 2007 | 09:35 AM
KrenzyRyan's Avatar
Default Re: Bob_760
OK, I think im going to try the Koyo, although I have the B16A swap like Bob, and I was looking on this site: http://www.statracing.com/buy/koyo-radiator.asp
Which would I go with? The Denso or the Showa?
Old Jul 24, 2007 | 11:13 AM
4g hatch's Avatar
Default Re: Bob_760 (KrenzyRyan)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob_760 &raquo;</TD></TR><TR><TD CLASS="quote">yay radiator thread lol (just got mine)
i love the pitt just being nosey. i have a brindle one. damn dogs crazy
