Any ways to clear Spoon Calipers on Rota Slipstream?
Old May 29, 2007 | 06:02 AM
EKRon's Avatar
Default Any ways to clear Spoon Calipers on Rota Slipstream?
Hi everyone,
Like to seek some advice regarding the above matter.
Is there any ways to clear spoon caliper on my EK4 with 15x7.0 +40 Offset Rota Slipstream?
Thanks in advance...
Old May 29, 2007 | 06:08 AM
Mr.EM1_EK's Avatar
Default Re: Any ways to clear Spoon Calipers on Rota Slipstream? (EKRon)
sell those rims and buy a bigger set.
Old May 29, 2007 | 06:14 AM
pdiggitydogg's Avatar
its a matter of offset, i believe
-> run spacers (with extended lugs if over 5mm)
[Ive never looked at the size of the caliper, but stock 15" itr wheels clear...apparently...]
Old May 29, 2007 | 06:33 AM
EKRon's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">its a matter of offset, i believe
-&gt; run spacers (with extended lugs if over 5mm)
[Ive never looked at the size of the caliper, but stock 15" itr wheels clear...apparently...]</TD></TR></TABLE>
Hi pdiggitydogg, I have thought of running a 5mm spacer too. But will that compromise the safety of the car?
Old May 29, 2007 | 06:35 AM
not really no
5mm isnt that big of a deal, but like I said, you can always mount extended lugs if youre paranoid about it
Old May 29, 2007 | 06:38 AM
LadyLuck88's Avatar
THis may help
https://honda-tech.com/zerothread/1996821
Modified by LadyLuck88 at 7:49 AM 5/29/2007
Old May 29, 2007 | 06:58 AM
EKRon's Avatar
Default Re: (LadyLuck88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LadyLuck88 &raquo;</TD></TR><TR><TD CLASS="quote">THis may help
Modified by LadyLuck88 at 7:49 AM 5/29/2007</TD></TR></TABLE>
That was very helpful. Thanks LadyLuck88.
Old May 29, 2007 | 06:57 PM
EKRon's Avatar
Default Re: (EKRon)
Anyone else tried putting Spoon Calipers on 15" rims? Any advices?
Old May 29, 2007 | 07:58 PM
JDM-EJ698's Avatar
Default Re: (EKRon)
ITR & CTR(same) are 15" wheels and will cover Spoon calipers.
Old May 29, 2007 | 09:35 PM
EKRon's Avatar
Default Re: (JDM-EJ698)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 &raquo;</TD></TR><TR><TD CLASS="quote">ITR & CTR(same) are 15" wheels and will cover Spoon calipers.</TD></TR></TABLE>
Hi JDM-EJ698, I have tried to fit my 15" Slipstream with the Spoon Calipers. Dun think it can fit in. This might be becos of the Knuckle different between the CTR, ITR and my EK4.
Old May 30, 2007 | 12:47 PM
JDM-EJ698's Avatar
Default Re: (EKRon)
I think you need a dif offset wheels.I've got ITR wheels on 98 HB.And I put my wheels in my buddies hb with spoon calipers and they fit pertfect.I think the offset you need is +45.
Old May 30, 2007 | 06:55 PM
EKRon's Avatar
Hmm, I tot by making the offset smaller, there will be a better chance of clearing it. If i am not wrong, the Spoon SW388 offset is +35. My friend advise me to put a 5mm spacer behind the rotors and that will solve the problem. Do u guys think it is a good way to solve the problem?
AssPenny
Jul 15, 2005 04:29 PM
under_psi
Apr 28, 2003 02:20 PM
IGGY
Mar 27, 2003 09:33 AM
Black R
May 17, 2002 08:30 AM
B2FiNiTY
Apr 22, 2002 02:32 PM
